Re: [Mpi3-ft] Defining the state of MPI after an error
We are kind of going in circles because the context and rationale for CANNOT_CONTINUE are still too ambiguous. My argument is against adding it into the standard first and figuring out later what it means. I will wait for the ticket. If the ticket gives a full and convincing specification of what the implementor and the user are to do with it,, I will make my judgement based on the whole description. If the ticket says "Put this minor change in today and we will decide later what it means, I must lobby the Forum to reject the ticket.. Note 1) all current errors detected by an MPI application map to an existing error class. An error cannot map to two error classes so if some user error handler is presently checking for MPI_ERR_OP after a non-SUCCESS return from MPI_Reduce and the implementation moves the return code for passing a bad OP from class MPI_ERR_OP to MPI_ERR_CANNOT_CONTINUE it has just broken a user code. 2) Mandating that every MPI call after a MPI_ERR_CANNOT_CONTINUE must return MPI_ERR_CANNOT_CONTINUE will require that every MPI call check a global flag (resulting in overhead and possible displacement of other data from cache) Dick Treumann - MPI Team IBM Systems & Technology Group Dept X2ZA / MS P963 -- 2455 South Road -- Poughkeepsie, NY 12601 Tele (845) 433-7846 Fax (845) 433-8363 From: Darius Buntinas <[email protected]> To: "MPI 3.0 Fault Tolerance and Dynamic Process Control working Group" <[email protected]> Date: 09/22/2010 05:47 PM Subject: Re: [Mpi3-ft] Defining the state of MPI after an error Sent by: [email protected] On Sep 22, 2010, at 2:29 PM, Richard Treumann wrote:
You lost me there - in part, i am saying it is useless because there are
almost zero cases in which it would be appropriate. How does that make it "a minor change"? Well I figure we're just adding an error class that the implementation can return to the user if it gives up and can't continue. That's minor. Whether or not it's useful is another story :-)
Can you provide me the precise text you would add to the standard? Exactly how does the CANNOT_CONTINUE work? Under what conditions does an MPI process see a CANNOT_CONTINUE and what does it mean?
I don't know yet. It might be something as simple as adding an entry to the error class table with a description like: Process can no longer perform any MPI operations. If an MPI operation returns this error class, all subsequent calls to MPI functions will return this error class.
Please look at the example again. The point was that there is nothing there that would justify a CANNOT_CONTINUE and MPI is still working correctly. Despite that, the behavior is a mess from the algorithm viewpoint after the error.
Since we haven't defined what happens in a failed collective yet, consider an implementation could will not continue after a failed collective. The odd numbered processes that did not immediately return from barrier with an error will continue with the barrier protocol (say it's recursive doubling). Some of the odd processes will need to send messages to some of the even processes. Upon receiving these messages, the even processes will respond with an I_QUIT message, or perhaps the connection is closed, so the odd processes will get a communication error when trying to send the message. In either case, the odd processes will notice that something's wrong with the other processes, and return an error. The second barrier will return a CANNOT_CONTINUE on all of the processes. OK, what if the odd processes can't determine that the even processes can't continue? The odd processes would hang in the first barrier, and the even numbered processes would get a CANNOT_CONTINUE from the second barrier. So we either get a hang, or everyone gets a CANNOT_CONTINUE but we avoided the discombobulated scenario. -d _______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
participants (1)
Richard Treumann
