Re: [Mpi3-ft] system-level C/R requirements
I was referring to the MPI stack supporting the PREPARE and RESTORE calls. Ideally we would like to take existing MPI applications and support C/R support without any modifications to their source. Similarly, if we can separate the requirements of C/R restart from the application design this allows the developer to focus purely on the problem their application is trying to solve and not on C/R requirements. However, if you intend to support C/R in a way that is completely separate from the MPI use of the application then you will have scenarios that a checkpoint is initiated while the application is blocking on an MPI_Recv(), MPI_Barrier(), or any other blocking operation. Therefore, for the most value the PREPARE and RESTORE operations should be able to be invoked asynchronously during the application's MPI communication. Mike Supalov, Alexander wrote:
Thanks. What stack do you mean here?
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Mike Heffner Sent: Saturday, October 25, 2008 2:48 AM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] system-level C/R requirements
Thanks. I think the word "how" below is decisive.
The definition of MPI_Init and MPI_Finalize do not say "how" processes are created, and still, they work. Likewise, as soon as we can define the expected outcome of the proposed calls, we can offload the "how" to the system - in this case, the CR system.
Now we come to the expected outcome. Imagine we guarantee that there's no MPI communication between the PREPARE and RESTORE calls, and no messages stuck in the wire or in the buffers. What can be stored in the system memory covered by CR will be stored there. The rest will be restored by the RESTORE call once it gets control over this memory image back. This may include reinitialization of the networking hardware, reestablishment of connections, reopening of the files, etc.
What other guarantees do CR people want?
If the stack supported these calls asynchronously during MPI communication -- either from a signal handler or from a second thread --
then I think that definition would go a fair way towards what would be required.
Mike
participants (1)
Mike Heffner
