Re: [Mpi3-ft] Defining the state of MPI after an error
Dick: You seem to be ignoring my use case. Specifically, I have tool threads that use MPI. Their use of MPI should be unaffected by all of the scenarios that you are raising. However, the standard provides no way for me to tell if they work correctly in these situations. I just have to cross my fingers and hope. FYI: Your implementation has long met this requirement (my hopes are not dashed with it). Others have begun to recently. In any event, I would like some way to tell... Further, it is useful in many other scenarios apply to know that the implementation intends to remain usable. I am not looking for a promise of correct execution; I am looking for a promise of best effort and accurate return codes. Bronis On Mon, 20 Sep 2010, Richard Treumann wrote:
If there is any question about whether these calls are still valid after an error with an error handler that returns (MPI_ERRORS_RETURN or user handler)
MPI_Abort, MPI_Error_string MPI_Error_class
I assume it should be corrected as a trivial oversight in the original text.
I would regard the real issue as being the difficulty with assuring the state of remote processes.
There is huge difficulty in making any promise about how an interaction between a process that has not taken an error and one that has will behave.
For example, if there were a loop of 100 MPI_Bcast calls and on iteration 5, rank 3 uses a bad communicator, what is the proper state? Either a sequence number is mandated so the other ranks hang quickly or a sequence number is prohibited so everybody keeps going until the "end" when the missing MPI_Bcast becomes critical. Of course, with no sequence number, some tasks are stupidly using the iteration n-1 data for their iteration n computation.
Dick Treumann - MPI Team IBM Systems & Technology Group Dept X2ZA / MS P963 -- 2455 South Road -- Poughkeepsie, NY 12601 Tele (845) 433-7846 Fax (845) 433-8363
participants (1)
Bronis R. de Supinski
