Re: [mpiwg-ft] [EXTERNAL] FTWG Readings for December 2019
Do we have the meeting today? Sent from my iPad On Nov 25, 2019, at 5:12 AM, Wesley Bland via mpiwg-ft <[email protected]> wrote: Hi all, The Fault Tolerance Working Group would like to announce the following items for the Albuquerque meeting: Readings Issue 143 - Create MPI_INFO_ENV before MPI_INIT Issue: https://github.com/mpi-forum/mpi-issues/issues/143 Pull Request: https://github.com/mpi-forum/mpi-standard/pull/126 Description: This proposes a new function called MPI_INFO_ENV_CREATE_ARGV which would allow the user to pass in the argc and argv parameters and receive an MPI_INFO_ENV-like object back, which could be used for all of the same functionality as MPI_INFO_ENV. Second Vote Issue 134 - Add MPI_ERR_PROC_ABORTED Issue: https://github.com/mpi-forum/mpi-issues/issues/134 Pull Request: https://github.com/mpi-forum/mpi-standard/pull/112 Description: The proposal adds the MPI_ERR_PROC_ABORTED error class, that can be returned by operations that fail due to an aborted process. Errata Issue 152 - Make error code functions thread-safe Issue: https://github.com/mpi-forum/mpi-issues/issues/152 Pull Request: https://github.com/mpi-forum/mpi-standard/pull/141 Description: Add MPI_ERROR_CLASS and MPI_ERROR_STRING to the list of always thread-safe functions. Thanks, Wesley _______________________________________________ mpiwg-ft mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft
participants (1)
Teranishi, Keita
