Re: [mpiwg-ft] [EXTERNAL] Re: FTWG Con Call Today
That is a great idea, Keita, and I will be happy to participate to explore the relative areas of strength of these respective models. I think the first steps should be: · define a (small) collection of workloads that represent major MPI usage models, such as: master worker, SPMD, small number of communicators with mostly point-to-point communications, many different communicators with mostly collective operations, strictly iterative (identical iterations) versus semi-iterative (same iterations, but data set sizes change due to Adaptive Mesh Refinement, for example), versus non-iterative (some graph problems, such as betweenness centrality), multi-physics models, hybrid MPI/threading models, one-sided communications, applications that use external libraries. Of course, these models are not mutually exclusive. We shouldn’t go crazy here, but make sure we have a sufficient basis for evaluation, and then parameterize these workloads. · Define various fault modes to be covered. Rob -----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Teranishi, Keita Sent: Tuesday, December 20, 2016 11:27 PM To: [email protected]; MPI WG Fault Tolerance and Dynamic Process Control working Group <[email protected]>; Bland, Wesley <[email protected]> Subject: Re: [mpiwg-ft] [EXTERNAL] Re: FTWG Con Call Today Ignacio, Yes, ReInit and Fenix-1.0 have the same recovery model. They use longjump for global rollback and fix MPI communicator at the end of "Init² call. I am very happy to perform the feasibility studies of these three (plus one) models. I think that it will be great if we can explore the feasibility through some empirical (prototyping) studies. As for 4th (ReInit/Fenix-1.0) model, we should have clear definition MPI communicator recovery including subcommunicators. In order to utilize the next generation checkpoint library (ECP¹s multi-level checkpointing project) or accommodate application specific recovery schemes, MPI_Comm should provide some information of its past (history failures or change in the rank, comm_size, etc.) as well as its current state. I am hoping that our experience with Fenix will help to design a new spec. Thanks, --------------------------------------------------------------------------- -- Keita Teranishi Principal Member of Technical Staff Scalable Modeling and Analysis Systems Sandia National Laboratories Livermore, CA 94551 +1 (925) 294-3738 On 12/20/16, 4:55 PM, "Ignacio Laguna" <[email protected]<mailto:[email protected]>> wrote:
Hi Keita,
I think we all agree that there is no silver bullet solution for the FT
problem and that each recovery model (whether it's ULFM, Reinit, Fenix,
or ULFM+autorecovery) works for some codes but doesn't work for others,
and that one of the solutions to cover all applications is to allow
multiple recovery models.
In the last telecon we discussed two ways to do that: (a) all models
are compatible with each other; (b) they are not compatible, thus the
application has to select the model to be used (which implies libraries
used by the application have to support that model as well). The ideal
case is (a), but we are not sure if it's possible, thus we are going to
discuss each model in detail to explore that possibility. I believe
case
(b) is always a possibility, in which case you can still run Fenix on
top of ULFM in that situation.
BTW, correct me if I'm wrong, but Reinit and Fenix share (at a
high-level) the same idea of global backward recovery with longjumps to
reinject execution; thus we should call the 4rth option perhaps
Reinit/Fenix.
Ignacio
On 12/20/16 3:06 PM, Teranishi, Keita wrote:
All,
Throughout the discussion, I am a bit worried about making MPI bigger
than message passing interface because I wish MPI to serve a good
abstraction of user-friendly transport layer. Fenix is intended to
leverage the minimalist approach of MPI-FT (ULFM today) to cover most
of online recovery models for parallel programs using MPI. The
current version is designed to support SPMD (Communicating Sequential
Process) model, but we wish to support other models including
Master-Worker, Distributed Asynchronous Many Task (AMT) and Message-Logging.
·ULFM: We have requested non-blocking communicator recovery as well as
non-blocking comm_dup and comm_split, etc. ULFM already provides good
mechanism to serve master-worker type recovery like UQ, model
reduction and a certain family of eigenvalue solvers. I wish to have
more fine control for revocation because it is possible to keep the
certain connection of survived process (for master-worker or
task-parallel computing), but it might be too difficult.
·ULFM + Auto recovery: I need clarification from Wesly (as my
knowledge is wrong most likelyŠ but let me continue based on my assumption).
Fenix assumes that failure happens at a single or a small number of
processes. In this model, auto-recovery could serve as
un-coordinated recovery because no comm_shrink call is used to fix the communicator.
This could help message reply of uncoordinated recovery model. For
example, recovery is never manifested as ³Failure² to the survived
ranks, making particular message passing calls very slow. For SPMD
model, adaptation is so challenging as the user needs to write how to
recover the lost state of failed processes. However, I can see a
great benefit for implementing resilient task parallel programming model.
·Communicator with hole: Master-Worker type applications will benefit
from this when making collectives to gather the data available.
·MPI_ReInit: MPI_ReInit is very close to the current Fenix model.
We have written the API specification (see attached) to support the
same type of online recovery (global rollback upon process failure).
The code is implemented using MPI-ULFM, and we have seen some issues
with MPI-ULFM that makes multiple communicator recovery convoluted.
We used PMPI to hide all the details of error handling, garbage
collection and communicator recovery. The rollback (to Fenix_Init) is
performed through longjmp. Nice features of Fenix are (1) an idea of
*resilient
communicator* that allows the users to specify which communicator
needs to be automatically fixed and (2) *callback functions* to
assist application-specific recovery followed by communicator
recovery. We originally do not intend Fenix to be part of the MPI
standard because we want the role of MPI confined within ³Message Passing² and do not want
delay the MPI standardization discussions. My understanding with
MPI_ReInit is standardizing online-rollback recovery and keeping
PMPI/QMPI layer clean through a tight binding with the layers
invisible to typical MPI users (or tool developers) --- Ignacio,
please correct me if I am wrong. My biggest concern of MPI_ReInit is
that defining rollback model by Message Passing Library may violate
the original design philosophy of MPI (again this is the reason why
we did not propose Fenix as MPI standard). Another concern is that
it might be difficult to keep other recovery options open, but it
gets much more flexible with a few knobs in the APIs. I think the
latter is easy to fix with some switches in APIs. I think we can
figure out the options as we discuss further.
Keita
*From: *"Bland, Wesley" <[email protected]<mailto:[email protected]>>
*Date: *Tuesday, December 20, 2016 at 1:48 PM
*To: *MPI WG Fault Tolerance and Dynamic Process Control working
Group <[email protected]<mailto:[email protected]>>, "Teranishi, Keita"
*Subject: *Re: [mpiwg-ft] [EXTERNAL] Re: FTWG Con Call Today
Probably here since we don't have an issue for this discussion. If
you want to open issues in our working group's repository
(github.com/mpiwg-ft/ft-issues), that's probably fine.
On December 20, 2016 at 3:47:25 PM, Teranishi, Keita
([email protected]<mailto:[email protected]>
<mailto:[email protected]>) wrote:
Wesley,
Should I do here or github issues?
Keita
*Date: *Tuesday, December 20, 2016 at 1:43 PM
You don't have to wait. :) If you have comments/concerns, you can
raise them here too.
On December 20, 2016 at 3:38:47 PM, Teranishi, Keita
([email protected]<mailto:[email protected]> <mailto:[email protected]>) wrote:
All,
Sorry, I could not make it today. I will definitely join the
meeting next time to make comments/suggestions on the three
items (ULFM, ULFM+Auto, and ReInit) from Fenix perspective.
Keita
*From: *<[email protected]<mailto:[email protected]>> on behalf of
*Reply-To: *MPI WG Fault Tolerance and Dynamic Process Control
working Group <[email protected]<mailto:[email protected]>>
*Date: *Tuesday, December 20, 2016 at 1:29 PM
*To: *FTWG <[email protected]<mailto:[email protected]>>
*Subject: *[EXTERNAL] Re: [mpiwg-ft] FTWG Con Call Today
The notes from today's call are posted on the wiki:
Those who have specific items, please make progress on those
between now and our next meeting. We will be cancelling the Jan
3 call due to the holiday. The next call will be on Jan 17.
Wesley
On December 20, 2016 at 8:15:06 AM, Bland, Wesley
The Fault Tolerance Working Group¹s biweekly con call is
today at 3:00 PM Eastern. Today's agenda:
* Recap of face to face meeting
* Go over existing tickets
* Discuss concerns with ULFM and path forward
Wesley
Join online meeting
Join by Phone
+1(916)356-2663 (or your local bridge access #) Choose
bridge 5.
Find a local number <https://dial.intel.com>
Conference ID: 757343533
Forgot your dial-in PIN? <https://dial.intel.com> | First
online meeting?
<http://r.office.microsoft.com/r/rlidOC10?clid=1033&p1=4&p2=1041&pc=oc
&ve
r=4&subver=0&bld=7185&bldver=0>
mpiwg-ft mailing list
_______________________________________________ mpiwg-ft mailing list [email protected]<mailto:[email protected]> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft
participants (1)
Van Der Wijngaart, Rob F
