How will you distinguish between an error that is the result of a bad parameter and a "detected fault" ? Rich Sent with Good (www.good.com) -----Original Message----- From: Darius Buntinas [mailto:[email protected]] Sent: Thursday, June 23, 2011 05:30 PM Eastern Standard Time To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: [Mpi3-ft] error vs fault I feel it would be easier to explain/understand FT related things if we distinguished between errors and faults, i.e., an error is a detected fault. I'd like to take a stab at running through the whole standard to make these changes. But before I spend time on this I'd like to make sure people are OK with it. I believe I'd have to be done with this by Wednesday. (right Josh?) Does anyone have objections? -d _______________________________________________ mpi3-ft mailing list mpi3-ft@lists . mpi-forum . org hxxp://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
participants (1)
Graham, Richard L.
