Re: [Mpi3-ft] notes from FT plenary and WG sessions for Sept. 2011 mpi forum meeting
Thanks for the detailed notes. We'll be sure to discuss these issues in the next teleconf, if not on the email list before then. Thanks again, Josh On Fri, Sep 23, 2011 at 5:53 AM, Howard Pritchard <[email protected]> wrote:
Hi Folks,
Here is a summary of my notes from both the plenary session and the working group. � Note that we did the WG before the plenary session.
Here is a summary of my notes from the working group session -
The fault tolerant collectives ideas were discussed. �Darius had questions about how useful the option for all ranks involved in a coll op to return the same error code saying the changes to handle this case vs just calling MPI_Comm_validate after the coll op regardless of the error code returned. �Everyone thought it would be good to have more info from apps people about why this feature - returning uniform error code - would be much better than the other option.
There was a lot of discussion of having a 'vector' version of the MPI_Comm_validate. �The WG thought it would be sufficient just replace the existing validate functions with vector versions, with the n=1 case being equivalent to the existing functionality.
Feedback from the Eurompi was discussed. Darius talked about a point someone had raised about what happens with MPI_Comm_split, etc. if an error occurs and the input communicator is still using errors are fatal error handler.
We also discussed what happens when the system can't start up as many ranks as the user requested on the mpiexec command line. �Darius pointed out that the MPI-2 standard already addresses this and said that for mpich2 now it just tries to start as many ranks as it can. �It was decided that how this situation is handled should be described in the "advice to implementers" in the mpiexec section of the spec.
First the plenary session -
Although it is not in the current proposal, Adam Moody brought up the MPI_Kill functionality again. �That was discussed and many objections were raised. �It is good that we did remove this from the run through stabilization proposal.
There was some discussion concerning RMA and how it relates to the current proposal. �It was agreed that the FT group needs to sync up with what the RMA group is doing to make sure there aren't any show-stoppers. �Brian Barrett also brought up the need to have an enumeration of the cases that occur for the existing and proposed RMA synchronization models and the run through stabilization proposal.
There was also discussion of the deprecated C++ bindings and how or if we expect to support fault tolerance when using the C++ bindings given the way errors are handled when using these bindings. �It was agreed that places in the proposal currently reading "return an error" need to be changed to "raised an error".
There was a lively discussion of the MPI_ANY_SOURCE issue and the functionality required to fix up a communicator for pt2pt when a process has MPI_ANY_SOURCE receives posted. �Some argued that it may be very difficult/impossible to support the cancel-like qualities of MPI_Comm_reenable_any_source.
George pointed out that we can't just complete-with-error anysource receives, we'll also need to complete-with-error any receive posted after the anysource receive that might match the anysource receive. Consider the example:
Proc0 � � � � � � Proc1 ----- � � � � � � ----- Recv(AS, TAGX)[A] Recv( 1, TAGX)[B] � � � � � � � � � Send(0, TAGX)[C] � � � � � � � � � Send(0, TAGX)[D]
Without failure, Recv A will match Send C and Recv B will match Send D. �If an unrelated process fails, and we only complete-with-error the anysource, then Recv A will complete with error, and Recv B will match Send C. �So we would need to complete-with-error all recvs posted after an anysource receive with tags that match the tag of the anysource receive.
This aspect of the proposal definitely needs reinvestigation/clarification. �It may also be necessary to discuss this in more detail with those interested in hardware based mpi tag matching.
Torsten was not convinced about the feasibility of implementing MPI_Comm_validate and friends from a theoretical standpoint. �He asked if someone has shown whether this is impossible. �The existing work by Josh concerning lit. etc may need to be reviewed the next time this proposal is presented to the forum.
There was some discussion of the "vector" version of MPI_Comm_validate. �The idea of just having a vector of 'comms' didn't seem to go over very well. �What seemed to be more palatable would be to have a first comm argument, followed by a vector of comms which are derived from the first comm.
Somehow we returned to looking at examples like the MPI_Bcast example in the proposal. �The early breakout from the loop caused very animated discussion, but no real consensus about what to do about this.
Aspects of communicator creation was also brought up. �A suggestion was given that for routines that create communicators, and for which the default errors are fatal errors are fatal error handle is associated with the input comm, that rather than immediately returning an error if the operation fails, the app would be allowed to attach a non-default error handler which would then raise the error, much like is documented for MPI_Init.
Howard -- Howard Pritchard Software Engineering Cray, Inc. _______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
-- Joshua Hursey Postdoctoral Research Associate Oak Ridge National Laboratory http://users.nccs.gov/~jjhursey
participants (1)
Josh Hursey
