Re: [Mpi3-ft] Persistent Communication & Sendrecv
I agree that the count=0 is odd (section 3.2.2 in case anyone is interested). Maybe it is for control messages where the buffer does not matter, just that you received a message (e.g., Barrier). I don't know if I follow the rest. So when I call: ------------------ MPI_Irecv(MPI_ANY_SOURCE, MPI_ANY_TAG, count=0, &req); MPI_Wait(req, status); ------------------ The field values in 'status' will match the incoming received message. This way the user can figure out from whom and with what tag this recv matched. Or with what error the request failed. If the user were to write: ------------------ MPI_Irecv(MPI_ANY_SOURCE, MPI_ANY_TAG, count=0, &req); MPI_Wait(req, status); MPI_Wait(req, status); ------------------ The second wait would return MPI_SUCCESS with an 'empty' status since the first wait destroys the request. For the persistent situation, the MPI_Wait does not destroy the request, but just sets it inactive. So in: ------------------ MPI_Recv_init(MPI_ANY_SOURCE, MPI_ANY_TAG, count=0, &req); MPI_Start(req); MPI_Request_get_status(req, flag, status); /* A */ MPI_Wait(req, status); MPI_Request_get_status(req, flag, status); /* B */ MPI_Wait(req, status); ------------------ The second MPI_Wait would still return an 'empty' status since the request is inactive. The MPI_Request_get_status in (A), if the request is finished, will set the flag to true and return a status with the various fields set to match the incoming message. If the request is still active then it will return false, and the 'empty' status. The MPI_Request_get_status in (B) will set the flag to true (the request is not active or null) and return 'empty' status. So in the Startall case the user can figure out which requests were started, which failed, and which were not started by checking the arguments returned by MPI_Request_get_status one at a time: forall requests call MPI_Request_get_status(req, flag, status) if( flag ) { if( status.error != success ) // Failed if( status == empty ) // Not started if( status != empty ) // Started, and now complete } else { // Started, and not yet complete } What am I missing? -- Josh On Aug 31, 2010, at 1:20 PM, Bronis R. de Supinski wrote:
Huh? No, the MPI_Recv_init creates a persistent request with MPI_ANY_SOURCE and MPI_ANY_TAG for those fields. Combined with the MPI_Startall, it is roughly the same as this:
MPI_Irecv (MPI_ANY_SOURCE, MPI_ANY_TAG, count=0, &req[1]);
(I'll admit the "count=0" arg is a bit odd). A wait on the started request can match any message (again, the count is a bit strange and Josh omitted the type arg but it is pseudocode so no big deal).
On Tue, 31 Aug 2010, Joshua Hursey wrote:
On Aug 31, 2010, at 1:09 PM, Fab Tillier wrote:
Joshua Hursey wrote on Tue, 31 Aug 2010 at 08:43:24
I was thinking more about MPI_Startall() this morning and found a situation where this technique would not work.
If the application does: -------------------- MPI_Send_init(rank=1, tag=123, req[0]); MPI_Recv_init(MPI_ANY_SOURCE, MPI_ANY_TAG, count=0, req[1]); MPI_Send_init(rank=2, tag=123, req[2]);
MPI_Startall(3, req) // Fails with MPI_ERR_IN_STATUS if( failed ) { for(i=0; i<3; ++i) { MPI_Request_get_status(req[i], flag, status); if( flag && status.error != success ) // Failed if( flag && status == empty ) // Not started if( flag && status != empty ) // Complete } } --------------------
The problem is with the definition of an 'empty' status which has (section 3.7.3): --------------------- source = MPI_ANY_SOURCE tag = MPI_ANY_TAG error = MPI_SUCCESS MPI_Get_count = 0 MPI_test_cancelled = false --------------------- So the successful completion of the MPI_Recv_init() call would be indistinguishable from the 'not started' or inactive state of the call.
Wouldn't a successful completion of the MPI_Recv_init() return a specific source and tag for the message actually received? The source and tag fields of the receive are for filtering incoming sends, but when the receive completes, it was matched to exactly one send, with a specific tag and source.
What am I missing?
Ah yes. You are correct. So this is not a problem then, and the MPI_Request_get_status() technique would be a good way to check the state of all of the requests.
Thanks, Josh
-Fab
_______________________________________________ mpi3-ft mailing list [email protected] http://*lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
------------------------------------ Joshua Hursey Postdoctoral Research Associate Oak Ridge National Laboratory http://*www.*cs.indiana.edu/~jjhursey
_______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
------------------------------------ Joshua Hursey Postdoctoral Research Associate Oak Ridge National Laboratory http://www.cs.indiana.edu/~jjhursey
participants (1)
Joshua Hursey
