Re: [Mpi3-ft] New RMA functions
The sync operations are all for remote completion. So, this is not an issue as far as RMA operations are concerned. If you can make do with the return codes, that'll be great. -- Pavan On 02/24/2011 11:04 AM, Darius Buntinas wrote:
Would we need to add a status object to the sync operations? We should be able to use the return code.
We may have issues with operations that complete locally and return MPI_SUCCESS, but then later fail when they actually perform the communication, but we already have this issue with regular sends.
I don't believe that we are making (or can make, without requiring every operation to be synchronous) the guarantee that if an operation returns MPI_SUCCESS that it was successfully delivered in the presence of a permanent failure (e.g., permanent network bisection or process failure).
-d
On Feb 24, 2011, at 9:53 AM, Pavan Balaji wrote:
1. The existing PUT/GET/ACCUMULATE operations which are from MPI-2.2. They will not take a request operand, and we want to retain it that way to minimize the performance overhead. Synchronization calls (such as closing an epoch or flush/flushall) wait for their completion, but they do not return a status object currently. Adding a status object to the synchronization calls is an option, though that'll require extensive changes. But adding them to the PUT/GET/ACCUMULATE operations themselves would beat the purpose of low-overhead communication, so that might not be doable.
_______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
