Re: [mpi3-ft] FW: Starting slides for 2/1/2008 telecon
Two comments: We may want to add the capability to spawn new processes and give them the ranks of the failed processes. This is more efficient than pre-allocating enough spare processes as part of the original job allocation, so it might be a good idea to include in the spec. I disagree with the comments about MPI quieting the communication system because this presumes that the application will use the trivial sync-and-stop CPR protocol. They may the case but we shouldn't write this assumption into the spec. We should probably restrict ourselves to only saying that no message may get partially delivered since such messages would be very hard to deal with above the MPI library. Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected] At 10:12 AM 1/29/2008, Richard Graham wrote:
This did not seem to make it through the first time, so let me try again.
Rich
------ Forwarded Message From: Richard Graham <[email protected]> Date: Tue, 29 Jan 2008 10:55:11 -0500 To: Discussion of MPI 3 Fault Tolerance Support <[email protected]> Conversation: Starting slides for 2/1/2008 telecon Subject: Starting slides for 2/1/2008 telecon
Attached is a set of slides I intend to use as a staring point for the telecon this coming Friday. If you are planning on attending, please take a look at these, and see what is missing. The main goal for this call is to help set the scope of the problem for which we intend to propose changes to the MPI standard.
Thanks, Rich
------ End of Forwarded Message
_______________________________________________ mpi3-ft mailing list [email protected] http://lists.cs.uiuc.edu/mailman/listinfo/mpi3-ft
participants (1)
Greg Bronevetsky
