Re: [Mpi3-ft] New version of the RTS proposal
I suspect that maybe I've confused myself thinking about this too much, and maybe it is best to talk at the teleconf today about this. I guess what was troubling me was in the scenario where MPI_INIT cannot complete successfully due to process failure (e.g., it messed up the connection establishment in a way that cannot be recovered). So MPI_Init bails out with an error. What can the MPI application do? It is not allowed to call MPI_Init again, and the state of the internal library is non-functional in this case. So in the example above, I would think that the MPI implementation would terminate the calling process because the user is left with no recourse in managing that scenario. The user may not be abel to even set an error handler or call MPI_Finalize. However if MPI_Init found a process failure during initialization, and was able to successfully setup the library in spite of the failure then I think we are in the safe zone for the user. We need MPI_Init to return success and raise an error at the next MPI operation. So we previously said that: "if a process failure occurs before or during MPI_INIT then MPI_INIT should try to raise and error and not abort by default." If MPI_Init raises an error then what does that mean to the application. If it is PROC_FAIL_STOP, does that mean that the MPI library is initialized, but detected a process failure? or does it mean that the MPI library is not setup because it returned an error (the operation failed). It might be better to say that MPI_INIT will -not- return an error of the class PROC_FAIL_STOP if a process failure is detected during MPI_INIT but the library initialized properly. This error is delayed until the next MPI call. ... But then what is the difference between detecting the process failure during MPI_INIT versus just afterward? Maybe I'm just troubled by the idea that MPI_INIT can return an error, but still have completed successfully. What do you all think? -- Josh On Tue, Nov 8, 2011 at 4:00 PM, Darius Buntinas <[email protected]> wrote:
I think what we have doesn't require it to complete successfully. �It says MPI_INIT should try to raise an error and not abort by default. �Then the advice to implementors says a critical error can make it abort.
However, I think maybe we should say that MPI_Init is not required to raise an error simply because it detected a process failure. �It should raise an error (and give an error on the next non-errhandler function blah blah...) if it is unable to initialize the library due to a process failure.
Or is this what you were suggesting?
-d
On Nov 7, 2011, at 12:58 PM, Josh Hursey wrote:
* We need to review 17.5.6: What if MPI_INIT does not internally complete successfully due to process failure? The text seems to assume that MPI_INIT will always be able to complete successfully in the presence of failure. Maybe we should state that 'if it is able to complete successfully, then it should even in the presence of failure'?
_______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
-- Joshua Hursey Postdoctoral Research Associate Oak Ridge National Laboratory http://users.nccs.gov/~jjhursey
participants (1)
Josh Hursey
