Re: [Mpi3-ft] system-level C/R requirements
Thanks. I can't speak for the whole Forum, but my impression is that if the choice will be between solving the problem of MPI and CR on one hand, and not solving it on the other hand, a reasonable proposal will go a long way toward convincing the majority, or at least moving the discussion to a still better proposal. As for the number of calls, this is question of ROI. We're going to add 200 or so fancy calls by the latest guess, while here we have just 2 that offer basic functionality of undeniable value. This should be acceptable. Finally, I don't know a more implementation specific call than MPI_Init. The proposed calls live close nearby. -----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Greg Bronevetsky Sent: Friday, October 24, 2008 10:51 PM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group; MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] system-level C/R requirements
Probably we should not try to define this, and encourage checkpoint/restart people work with particular MPI implementations to make sure things work? After all, it's not about an abstract MPI and abstract CR system - there will probably always be actual pairs (or other relationships) of them that can work together.
Compare this to the situation with threads. MPI acknowledges their existence and provide a couple of calls to request a particular level of support, that's all. This was good enough for starters, and may change in the future. The relation between MPI and CR may go this way, too: acknowledging first, integrating next.
If all that you want to add to the spec is a couple of calls to say that MPI state should be frozen in some sense, that's fine with me since we're defining what these calls do. However, I'm not sure that the wider forum will accept them because there is a general dislike for adding more calls and the primary value of these calls is to motivate people to provide implementation-specific definitions for them, which I'm guessing is lower than the standard bar for acceptance. Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected] _______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
participants (1)
Supalov, Alexander
