Re: [mpiwg-ft] FTWG Call Today
Notes are now posted on the wiki: https://github.com/mpiwg-ft/ft-issues/wiki/2017-04-26 Ignacio will work on getting the necessary approval to post the slides and then those will be posted as well. On Apr 26, 2017, at 2:26 PM, Aurelien Bouteiller <[email protected]<mailto:[email protected]>> wrote: Ignacio, could you circulate the slides I can’t join the Skype. Aurelien On Apr 26, 2017, at 14:16, Bland, Wesley <[email protected]<mailto:[email protected]>> wrote: That's OK, we are not only fault tolerant, but also latency tolerant. -----Original Message----- From: [email protected]<mailto:[email protected]> [mailto:[email protected]] On Behalf Of Ignacio Laguna Sent: Wednesday, April 26, 2017 11:15 AM To: MPI WG Fault Tolerance and Dynamic Process Control working Group <[email protected]<mailto:[email protected]>>; Bland, Wesley <[email protected]<mailto:[email protected]>> Subject: Re: [mpiwg-ft] FTWG Call Today Yes, I should be able to do that. I may be around 5 minutes late though. -- Ignacio Laguna Center for Applied Scientific Computing (CASC) Lawrence Livermore National Laboratory Phone: 925-422-7308, Fax: 925-422-6287 On 4/26/17 9:27 AM, Bland, Wesley wrote: Hi FTWG, If I'm not mistaken, we have an FTWG con call today. On the agenda is continuing the discussion of the concerns around ULFM. Ignacio, are you ready to present the Reinit slides you had a month or two ago while I was out? Here's the call-in information: ......................................................................................................................................... Join online meeting https://meet.intel.com/wesley.bland/WBF3C1SD Join by Phone +1 ((916) 356-2663 (or your local bridge access #) Choose bridge 5. Conference ID: 494710807 ......................................................................................................................................... Thanks, Wesley _______________________________________________ mpiwg-ft mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft _______________________________________________ mpiwg-ft mailing list [email protected]<mailto:[email protected]> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft _______________________________________________ mpiwg-ft mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft
participants (1)
Bland, Wesley
