Re: [mpiwg-ft] help with advice to implementors accompanying MPI_Abort
It does not appear to me that any change is necessary. The only part about MPI_COMM_WORLD is in an 'as an example' clause. That being said, substituting MPI_COMM_WORLD with some generic 'communicator comm' would also work. Aurelien On Tue, Jun 25, 2019 at 9:49 AM Pritchard Jr., Howard via mpiwg-ft < [email protected]> wrote:
Hello MPI FTer’s,
The Sessions WG could use some help/suggestions about how to adjust the following advice to implementors that accompanies the definition of MPI_Abort:
\begin{implementors}
After aborting a subset of processes, a high quality implementation should
be able to provide error handling for communicators, windows, and files
involving both aborted and non-aborted processes. As an example, if the
user changes the error handler for \const{MPI\_COMM\_WORLD} to
\const{MPI\_ERRORS\_RETURN} or a custom error handler, when a subset of
\const{MPI\_COMM\_WORLD} is aborted, the remaining processes in
\const{MPI\_COMM\_WORLD} should be able to continue communicating with each
other and receive appropriate error codes when attempting communication
with an aborted process.
\end{implementors}
We would like to generalize this advice to implementors to the case where MPI_COMM_WORLD isn’t a valid communicator, i.e. when an application is using the Sessions model.
We think that there would need to be some reworking of the existing text to cover the sessions use case. Since the FT group has worked quite a bit on this text, we’d defer to your group for suggestions on how to generalize this text to cover the sessions use case.
Thanks very much for any help,
Howard
Howard Pritchard
HPC-ENV
Los Alamos National Laboratory
_______________________________________________ mpiwg-ft mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft
participants (1)
Aurelien Bouteiller
