Re: [Mpi3-ft] Point-to-point Communications recovery
This implies that layered s/w (application or middleware) would be responsible for regenerating any lost traffic, if this is needed. Perhaps if would make sense to provide the ability for upper layers to register a recovery function that could be called after repair() is done with restoring MPI internal state. Would this function be called on the surviving processes? I'm not sure that is is necessary. It seems that a simpler way to go is to allow any subsequent MPI calls to block as necessary until the appropriate repairs have been completed. This way the MPI implementation can choose exactly when to do individual repairs and may in fact choose to perform the repair between the time it detects the problem and the time it informs the application.
Greg, is the piggy-back capability you are asking for intended to help getting the application level communications reset to the state just before failure, so that the application can continue ?
Yes, exactly. Piggybacking + non-blocking everything makes it possible for middleware to coordinate checkpointing and log enough message and non-determinism information to restore any needed communication. Having a piggybacking API is necessary to ensure good performance. It is ok not to have all operations be non-blocking but if that is the case, we'll need good semantics on what happens when a process participates in a communication that involves the failed process (I'll define "good" later since I doubt the details matter now). Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected]
participants (1)
Greg Bronevetsky
