[Mpi3-ft] RTS Proposal v6 - Final Draft
I uploaded the 6th revision of the RTS proposal to the wiki. This revision includes the changes at bottom. * https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/276 * https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/ft/run_through_stabilizati... * https://svn.mpi-forum.org/trac/mpi-forum-web/attachment/wiki/ft/run_through_... Please take a look over the document if you have not already. I intend to send this out to the MPI Forum mailing list Thursday at around 1 p.m. EDT. The PDF will be attached to both the ticket and the email sent to the full forum. I updated the ticket with some setup text if you would like to review (PDF to be attached tomorrow): * https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/276 Thanks, Josh Change Log: * 3.7.3: Adjust wording to "- such an error must be treated as fatal which has the same effect as calling MPI_ABORT on MPI_COMM_SELF." * 17.2: Updated the definitions of 'error' and 'failure' (and new citation) -- Joshua Hursey Postdoctoral Research Associate Oak Ridge National Laboratory http://users.nccs.gov/~jjhursey
participants (1)
Josh Hursey
