Re: [Mpi3-ft] MPI Fault Tolerance scenarios
Right. The low-level interface may be optional.
That would be an interesting choice for the API: provide several levels of support and for each level provide an optional lower-level API that can be used to control recovery more finely than would be possible using the default error handlers. I think that we'll need an explicit communicator rejoin API even when using built-in error handlers but at least we won't force users to manually check error codes. Having this double stack leaves me worried that the low-level API will simply get dropped because the rest of the forum will not see the need for something that complicated. However, I think we'll have a few very persuasive arguments such as the fact that checking for failures immediately after every collective will have a huge performance hit, whereas giving control to the user will make it efficient. Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected] http://greg.bronevetsky.com
participants (1)
Greg Bronevetsky
