Re: [Mpi3-ft] Clarification Ticket 323: MPI_ANY_SOURCE and MPI_Test(any)
I believe I agree with everything you wrote. I also believe that our previous draft stated what happens for a blocking MPI_ANY_SOURCE recv ("In all other cases, the operation must return MPI_ERR_PROC_FAILED"), but during our rework of that text we no longer state what happens when a blocking MPI_ANY_SOURCE recv sees a failure. I'd like to avoid making many changes between our last reading and the first vote because late changes don't inspire confidence, but I think Josh's issue is valid. Personally I was always in favor of blocking and non-blocking recv on MPI_ANY_SOURCE failing if any process fails. The recv can complete as failed with the status pointing to the failed process. The user can still call MPI_Comm_failure_ack to exclude failed ranks from triggering further failures in MPI_ANY_SOURCE. I don't see the value in MPI_ERR_PENDING. Reposting the recv is not a big deal and we don't care that much about performance in the failure case. Still, I'd prefer any change that can address Josh's issue with the least change to the proposal. Thanks, Dave From: Josh Hursey <[email protected]> To: "MPI 3.0 Fault Tolerance and Dynamic Process Control working Group" <[email protected]> Date: 03/16/2012 08:54 AM Subject: [Mpi3-ft] Clarification Ticket 323: MPI_ANY_SOURCE and MPI_Test(any) Sent by: [email protected] I believe my reasoning is correct below, but thought I would ask the group to confirm. Consider the following code snippet: --------------------- MPI_Irecv(..., MPI_ANY_SOURCE, ..., &req); /* Some other process in the communicator fails */ MPI_Test(&req, &flag, &status); --------------------- The proposal in #323 says that the request should be marked as MPI_ERR_PENDING and not complete. So what should the value of 'flag' and 'status' be when returning from MPI_Test? According to the standard, 'flag = true' indicates two things: 1) the operation is completed 2) The 'status' object is set For the MPI_ANY_SOURCE case above, the operation is -not- completed, so (1) is violated; therefore I think MPI_Test should set 'flag' equal to 'false'. However, is the 'status' also not set? Should MPI_Test return MPI_SUCCESS or MPI_ERR_PENDING? If MPI_Test is to return MPI_ERR_PENDING directly, then there is no needed to inspect 'status'. However if we replace MPI_Test with MPI_Testany(1, &req, &index, &flag, &status) then the operation would return MPI_ERR_IN_STATUS, and the user must inspect the 'status' field for the true error value. So we would still set 'flag = false', but would also need to set the 'status'. That is if we want MPI_Test* return an error code that indicates that the request as 'failed, but not completed'. According to the standard, if no operation is completed then MPI_Testany "returns flag = false, returns a value of MPI_UNDEFINED in index and status is undefined." So according to the MPI_Testany logic, in this case 'flag = false', 'status is undefined', and the operation should return MPI_SUCCESS. Is that the expected behavior for the code snippet above? I think so, but I thought I would double check with the group. This means that the user can only 'see' the MPI_ERR_PENDING state of the request when they call an MPI_Wait* operation, which might not be what they would normally want to do (because they do not want to block). -- Josh -- Joshua Hursey Postdoctoral Research Associate Oak Ridge National Laboratory http://users.nccs.gov/~jjhursey _______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
participants (1)
David Solt
