Le 25 sept. 2013 à 18:51, Bronis R. de Supinski <[email protected]> a écrit :
Wesley:
I disagree vehemently with your statement that "either one individually would be useless." While I was not at the meeting (and thus did not raise the objections or make this suggestion -- this time), I consider this statement to be a continued example of how those working on the proposal have failed to understand what users most desire from MPI in terms of a first step for fault tolerance. The biggest concern is simply that the MPI standard states on p28:24-26:
This document does not specify the state of a computation after an erroneous MPI call has occurred. The desired behavior is that a relevant error code be returned, and the effect of the error be localized to the greatest possible extent.
I believe at least one other example exists of this sort of text but I will not look for it now. The point is that the user has no guarantees about the state of MPI, the computation or anything else after an error. While that may be unavoidable, the user also has no why to query the implementation about what the most likely state is. Thus, the user must make the most pessimistic assumption and catching an error is pretty much useless other than to implement some very basic message - or if the user is feeling frisky, some more complex action - prior to shutdown soon after the error is observed.
Bronis, You fail to understand that beside Shrink, the entire proposal is focused on defining exactly this piece: how the application can understand and resolve the consequence of failures. This proposal has 2 parts, one is giving the opportunity for applications to get that a failure impacted them. This can be can be very simple for some applications, but it can also be rather complex for some with transitive communication patterns, hence the need for some extra bullets like Revoke and Agree, beyond simple error codes. If you stay at the error code level, some application patterns will remain deadlocked (granted, some other application pattern do not need this, good for them, we split the logic in error codes and separate calls so that they can invoke the appropriate level of consistency only when needed). I invite you to read the papers we published that explain all the rationale. I'm sure you'll see the point more clearly then. The second one is Shrink, which is very simple, has no cost on performance, and is of undisputed usefulness to numerous users, if not most. So in essence, you want to have 2 proposals, one that contains everything, the other one with shrink only. There's no point in this.
I think the working group has listened to a small set of users No, we have not. We do have users doing coordinated Checkpoint/restart, bag of tasks, or coordinated algorithmic recovery. Our point is to define MPI state and how to make it communicative again, nothing more. Thereby our users are every code that wants to resume communicating after a failure. I have the impression that you believe that we can do ABFT only (or that it is a favored citizen), which is as far from truth as it can get. I reiterate, our goal is to enable applications (whatever FT method they use) to communicate again, nothing more, but nothing less (meaning all applications, even those with complex communication patterns that would deadlock irremediably with your truncated error reporting model).
and missed that the vast majority of users would be happy (at least initially) if the standard provided such a capability. I have spoken to numerous users for whom this statement is true. Further, such a capability would be fairly easy to make low cost. While some details would need to be worked out, Devil is in the details. If you actually tried to figure them out, you would have found the difficulties along the path and you would know that what you propose doesn't work.
Best, Aurelien
which would take time, you would find wide acceptance of that approach -- as opposed to trying to ram your complex, unintuitive interface down the throats of those who object.
That brings me to my other major objection to your email, You state "I think we all expect that this proposal won't be passing unanimously." The point of deferring the FT proposal was not to have it pushed with increase urgency. The point was to have objections addressed and to make the adopted interface broadly accepted. You still seem to think that a narrowly passed proposal would be OK.
Bronis
On Wed, 25 Sep 2013, Wesley Bland wrote:
Let me add my two cents here as well.
As Jim mentioned, this wasn't a rehashed slide deck. This was a new one. The confusion may have come from the fact that there haven't been any changes to the proposal recently and the talk that Rich gave was designed to be informational for those who hadn't attended the US meetings recently.
As Jim mentioned, this was really supposed to be a justification talk to give background and rationale. It sounds like we may not have achieved that goal. It's unfortunate that more of us couldn't be there to help the conversation, but I'd like to try to find out more about the specific concerns that were raised as we've been working very hard to respond to these sorts of things in the past.
I don't know if you actually meant that there was a desire to see the proposal split in two or not, but I'd really be against that. It would present a lot of work and without both pieces, either one individually would be useless. We've gone through the text many times to be sure that we're presenting the least intrusive interface possible that still accomplishes all of the needs of FT. As you mentioned, it isn't the most user friendly interface and we don't expect it to be. However, the real user friendly interfaces (C/R, replication, migration, strong consistency, etc.) can be built on top of the proposal, which is what we intended in our design. If that's one of the objections, then we many need to rethink things here or do a better job of convincing the forum that this is a good idea. FWIW, I believe that was always the original intent of MPI anyway.
If it's going to be a problem to bring this to the forum for a reading in December, we can push things out, but we've been targeting that date and I'd like to have a better idea of what the objections are before we decide to delay again. If it's just the same arguments again, then it may not do any good to push this for another 3-6 months. I think we all expect that this proposal won't be passing unanimously.
Thanks for the feedback Martin. I know that you probably weren't the one objecting and those who were probably aren't on this list. It's too bad that more of us couldn't be at the meeting, but I think we're all familiar with the funding situation in the US right now for international travel.
Thanks, Wesley
On Sep 25, 2013, at 8:23 AM, Jim Dinan <[email protected]> wrote:
Hi Martin,
The slides that were presented in Madrid were actually a new deck. We had tried to address feedback that there is a need to do a better job of covering the core issues, potential approaches, and justifications for design decisions, beyond just presenting the proposal. It sounds like more discussion around these topics is needed, and we can work with that for the Chicago meeting.
It sounds like we're being asked to break the proposal up into two sets of changes -- one that defines failures in MPI and MPI's state after a failure; and second that adds a recovery API. Is that right? I'm not sure if it's possible to tease these things apart, but we can look into it.
Cheers, ~Jim.
On Tue, Sep 24, 2013 at 2:48 PM, Martin Schulz <[email protected]> wrote:
Hi all,
This is more from the viewpoint of an external observer, since I haven't had the time to really participate lately.
Rich gave a presentation covering the current proposal, but he also said that this was basically the old slide deck that had been shown before and didn't contain any of the new work that the FT group has been doing in coordinating with the other WGs. There were also several questions that people asked and that we couldn't answer since Rich was the only FT group member at the meeting.
Based on this I got the feeling that many in the forum were still concerned about this overarching proposal and would like to hear more. In particular, a few meetings back after the MPI 3.0 vote we had a discussion about what was missing to make such concerns go away and one thing that we agreed on was to first go through the standard and clean things up to make it compatible with an FT proposal. From what I can tell, a lot of this has happened and it may help to explicitly present that before even going into the API approach. This (plus an updated talk with a broader discussion with more FT group members being present) may be better for the Chicago meeting than doing an actual formal reading (which may be too early since there doesn't seem to be consensus about the approach, yet).
From the application side, I have seen a few people starting to use it. One of our PDs is using it for a large MD application and there is also the following work I saw at a recent conference:
ftp://ftp.inf.ethz.ch/pub/publications/tech-reports/7xx/793.pdf
Both said that the interface is overly complex and has a very (too?) high of an impact on applications, which makes me worried. Not sure how we can address this, though.
Martin
On Sep 19, 2013, at 6:43 PM, Aurélien Bouteiller <[email protected]> wrote:
I am currently in Europe and busy. My schedule will get back to normal in october.
I'm also interested in a summary of events though.
Aurelien
Le 20 sept. 2013 à 00:42, Wesley Bland <[email protected]> a écrit :
Hi WG,
I've been out if the loop for a bit since my wife had our first baby last week (everyone is doing great). I was wondering how things went at the forum meeting last week. Was there any feedback from those in attendance?
Also, I didn't see an email about this week's con call. I assume that it didn't happen, but if it did can anyone mention what was discussed?
Thanks, Wesley _______________________________________________ mpiwg-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-ft
-- * Dr. Aurélien Bouteiller * Researcher at Innovative Computing Laboratory * University of Tennessee * 1122 Volunteer Boulevard, suite 309b * Knoxville, TN 37996 * 865 974 9375
________________________________________________________________________ Martin Schulz, [email protected], http://people.llnl.gov/schulzm CASC @ Lawrence Livermore National Laboratory, Livermore, USA
participants (1)
Aurélien Bouteiller
