I think that the main objection was not to the MPI_PROC_NULL semantics themselves, but the fact that querying and setting the state of a communicator is not thread safe. One thread can ask how many ranks are in a given state on comm A and another rank can then change the state of the comm by setting a rank to MPI_PROC_NULL, invalidating the results of the first thread's query. If we remove the ability to explicitly change the state of a rank, then notification can be handled in a more thread-safe way. Our argument was that separate threads should not be working with the same comm at the same time as this doesn't work well currently (e.g. two threads trying to call collectives on the same comm at the same time). In general, I think that if there was a way to do what we wanted without introducing 40? state quering/setting functions we would get less pushback. Getting rid of the MPI_PROC_NULL state opens up several options to such a simplification. [[ personal opinion: I think MPI_PROC_NULL semantics is a nice touch, though it is a guess how much it would actually get used vs. immediately calling MPI_Comm_split or someday calling MPI_Comm_restore. I'd be willing to drop it if it allowed us to move forward. ]] Thanks, Dave -----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Graham, Richard L. Sent: Thursday, July 21, 2011 12:46 PM To: 'MPI 3.0 Fault Tolerance and Dynamic Process Control working Group' Subject: Re: [Mpi3-ft] radical idea? Since I missed the meeting - what were the objections people had to the proc null semantics ? Is the suggestion that the app explicitly deal with the missing rank all the time, or something else ? What was the motivation ? What were the problems they saw ? What were the alternative suggestions ? Rich Sent with Good (www.good.com) -----Original Message----- From: Howard Pritchard [mailto:[email protected]] Sent: Thursday, July 21, 2011 01:08 PM Eastern Standard Time To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] radical idea? Hi Darius, If we want to get something about RTS into MPI 3.0 I don't think we have time to manage it as a set of smaller proposals. If we can eliminate the state problem that bothered some at the last forum meeting that would be a good start. Also, if we could simplify the proposal some by removing the PROC_NULL semantics, I would be in favor of that. If we want to limit the use of RTS to a small number of use cases (like the NOAA example), then I could see deferring "repairable" communicators to 3.1. Howard Darius Buntinas wrote:
We could break the rts proposal into smaller ones:
point-to-point: local up/down checks; errors on sending to failed processes recognition/PROC_NULLification: Add a function to set a rank in a communicator to MPI_PROC_NULL fault-aware collectives: collectives don't hang, but they're permanently broken once a proc in the communicator fails "repairable" collectives: validate_all; collectives can be reactivated after failure
I don't think anyone really objected to "point-to-point" or "fault-aware collectives". We'll have to work on the others.
-d
On Jul 20, 2011, at 9:13 AM, Joshua Hursey wrote:
I'll have to think a bit more and come back to this thread. But I wanted to interject something I was thinking about on the plane ride back. What if we removed the notion of recognized failures?
This was a point that was mentioned a couple times in discussion - that we have a bunch of functions and extra state on each communicator because we want to allow the application to recognize failures to get PROC_NULL semantics. If we remove the notion of recognized failures, then the up/down state on the group would be enough to track. So failed processes will always return an error regardless of if the failure has been 'seen' by the application before or not.
The state of a process would be able to change as MPI finds out about new failures. But we can provide a 'state snapshot' object (which was mentioned in discussion, and I think is what Darius is getting at below) to allow for more consistent lookups if the application so desires. This removes the local/global list tracking on each handle, and moves it to a separate object that the user is in control of. The user can still reference the best known state if they are not concerned about consistency (e.g., MPI_Comm_validate_get_state(comm, ...) vs MPI_Snapshot_validate_get_state(snapshot_handle, ...)).
Some applications would like the PROC_NULL semantics. But if we can convince ourselves that a library on top of MPI could provide those (by adding the proc_null check in the PMPI layer), then we might be able to reduce the complexity of the proposal by pushing some of the state tracking responsibility above MPI.
I still have not figured out the implications on an application using collective operations if we remove the NULL state, but it is something to think about.
-- Josh
On Jul 19, 2011, at 6:11 PM, Darius Buntinas wrote:
The MPI_COMM_NULLIFY() function would effectively set the process to MPI_PROC_STATE_NULL.
In the proposal we had MPI_PROC_STATE_NULL, _FAILED and _OK. I'm proposing separating NULL from FAILED and OK. So the MPI_COMM_GET_STATE() function (and friends) would let you query the (locally known) FAILED/OK state of the process, while MPI_COMM_NULLIFY() (and friends) would let you set the process to NULL. There would be essentially two state variables associated with each process: one indicating whether it's failed or not (let's call it LIVENESS), and the other whether it's has PROC_NULL semantics (call it NULLIFICATION). The LIVENESS state is controlled by the MPI library while the NULLIFICATION state is controlled by the user. The table below shows how these states would match up with the current proposal:
Current proposal state LIVENESS NULLIFICATION -----------------------+----------+--------------- MPI_PROC_STATE_OK OK NORMAL MPI_PROC_STATE_FAILED FAILED NORMAL MPI_PROC_STATE_NULL FAILED NULL <UNDEFINED> OK NULL
Notice that there's a combination possible that's not covered by the current proposal. I'm not sure whether that's a useful state (or if we should disallow it).
We'd could add a function to set the NULLIFICATION state from NULL to NORMAL for completeness.
-d
On Jul 19, 2011, at 4:32 PM, Solt, David George wrote:
This works for "reading" state, but has no way to set a processes state. (Not sure how radical your trying to go here... is part of the change here that there would no longer be a MPI_PROC_STATE_NULL state?) Dave
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Darius Buntinas Sent: Tuesday, July 19, 2011 3:17 PM To: Darius Buntinas Cc: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] radical idea?
Howard pointed out that I forgot to add a FREE operation:
MPI_PROC_STATE_FREE(state_handle) INOUT: MPI_PROC_STATE state_handle
-d
On Jul 19, 2011, at 3:07 PM, Darius Buntinas wrote:
MPI_COMM_GET_STATE(comm, state_handle) IN: MPI_COMM comm OUT: MPI_PROC_STATE state_handle and ditto for GROUP, FILE, WIN as necessary
MPI_GET_PROC_STATE_SIZE(state_handle, mask, size) IN: MPI_PROC_STATE state_handle IN: int mask OUT: int size
MPI_GET_PROC_STATE_LIST(state_handle, mask, list) IN: MPI_PROC_STATE state_handle IN: int mask OUT: int list[]
MPI_GET_PROC_STATE_NEW(state_handle1, state_handle2, state_handle_new) IN: MPI_PROC_STATE state_handle1 IN: MPI_PROC_STATE state_handle2 OUT: MPI_PROC_STATE state_handle_new This gives newly failed processes in state_handle2 since state_handle1.
mpi3-ft mailing list [email protected] hxxp://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
_______________________________________________ mpi3-ft mailing list [email protected] hxxp://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
-- Howard Pritchard Software Engineering Cray, Inc. _______________________________________________ mpi3-ft mailing list [email protected] hxxp://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft _______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
participants (1)
Solt, David George
