Re: [Mpi3-ft] Ticket #307: Behavior of MPI_INIT after failure to initialize
I do not thing there was any conclusion here - this is even true when one is not worrying about FT. What do you do when mpirun does not give you the number of process you asked for ? Before MPI_INIT we are not guaranteed to have more than a single "process". Rich -----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Wesley Bland Sent: Wednesday, May 08, 2013 11:18 AM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] Ticket #307: Behavior of MPI_INIT after failure to initialize Is there anything else from this ticket that we would find useful before killing it? For example, all of the text we have about MPI_INIT in ULFM is in an advice to implementors. Should we move anything to normative text? On May 8, 2013, at 10:06 AM, Aur�lien Bouteiller <[email protected]> wrote:
My memory is that this ticket has been combined, upgraded and included into ULFM.
Le 7 mai 2013 � 17:40, Wesley Bland <[email protected]> a �crit :
author: jjhursey
https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/307
This ticket specifies the behavior of the MPI library after a during MPI_INIT. Basically, if there is a failure during INIT, the library should return an appropriate return code and calling any other MPI function (with a few exceptions) is erroneous and will trigger the error handler for MPI_COMM_WORLD, which by default is MPI_ERRORS_ARE_FATAL and cannot be changed in this instance.
Again, this ticket has no discussion attached to it. I remember some discussions from the RTS proposal days, but I don't remember the results of any of those discussions. Can anyone else bring this back to light? _______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
-- * Dr. Aur�lien Bouteiller * Researcher at Innovative Computing Laboratory * University of Tennessee * 1122 Volunteer Boulevard, suite 309b * Knoxville, TN 37996 * 865 974 9375
participants (1)
Richard Graham
