Re: [mpiwg-ft] [EXTERNAL] Re: FTWG Call Today
Ignacio, Does your technique creates replacement of main() (say main_reinit()) that makes a setjump() call inside? It’s interesting. Many scientific libraries make MPI_Init() call inside their initialization functions (such as PETSc_initialize() and BLACS_Init() ). I am not 100% sure how PETSC_Initialize() can return to the replacement of main(). Could you clarify the behavior of these functions maiking MPI_Init() call. BTW (including SC14 version), Fenix_init() is a macro that is expanded to three function calls. So the user cannot call outside main() ☹. Fenix_preinit(); Setjump(); Fenix_postinit(); For this reason, when using PETSc with Fenix, I have to expose fenix_init() to main(). I cannot put inside petsc_initialize(). After all, I ended up wroting petsc_reintialize() to modify the contents created by petsc_initialize(). If your approach works, I can put Fenix_init() and petsc_reinitalize_fenix() inside petsc_initialize(), making the code much cleaner. Main() { petsc_initialize(); <= this is calling MPI_Init(); Fenix_init(); petsc_reinitialize_fenix(); : : : } Thanks, Keita On 3/15/17, 10:46 AM, "[email protected] on behalf of Ignacio Laguna" <[email protected] on behalf of [email protected]> wrote: Hey Aurelien, Thanks! I understand the concern. For gloabal-restart models like Reinit (and I believe that for the SC14 version of Fenix) this problem is solved by passing a reinit function pointer to MPI, which it then calls after initialization (this function is a replacement of main, and has the code that main originally contained). Since this reinit function is kept in the stack (it never returns), we can always long jump there. I think the main problem is that we cannot long jump from a signal handler, or more specifically it is undefined according to the C language. We would need to find another mechanism for long jumping after a signal handler is called as a result of a failure notification. Ignacio On 3/15/17 8:41 AM, Aurelien Bouteiller wrote: > > Hey Ignacio, > > Murali wanted to touch with you on that exact issue. The bottom line is > that a setjump must be in the same stack frame as the long jump, which > means that you can jump only to a function in which you are nested in. > In many cases that means you can’t “hide” set jumps points in the > library, as they have to be called in the application function context > (so that they remain in your frame). > > Best, > Aurelien > >> On Mar 14, 2017, at 18:15, Ignacio Laguna <[email protected] >> <mailto:[email protected]>> wrote: >> >> Thanks for sharing the minutes. >> >> In the "scoped reinit-like approaches", there is the point of "still >> subject to the longjmp complication". Can folks comment on what is the >> issue with respect to setjump/longjump in global-restart approaches, >> such as Reinit and/or Fenix? >> >> Thanks! >> >> Ignacio >> >> >> On 3/14/17 1:49 PM, Aurelien Bouteiller wrote: >>> Minutes for the call have been posted here: >>> https://github.com/mpiwg-ft/ft-issues/wiki/2017-03-14 >>> >>>> On Mar 14, 2017, at 15:00, Aurelien Bouteiller <[email protected] >>>> <mailto:[email protected]> >>>> <mailto:[email protected]>> wrote: >>>> >>>> Hi there, >>>> >>>> Aurelien Bouteiller is inviting you to a scheduled Zoom meeting. >>>> >>>> Topic: MPI FT WG >>>> Time: Mar 14, 2017 3:00 PM Eastern Time (US and Canada) >>>> >>>> Join from PC, Mac, Linux, iOS or >>>> Android: https://tennessee.zoom.us/j/607816420?pwd=MuG6Nboy9%2Fo%3D >>>> Password: beef >>>> >>>> Or iPhone one-tap (US Toll): +14086380968,607816420# or >>>> +16465588656,607816420# >>>> >>>> Or Telephone: >>>> Dial: +1 408 638 0968 (US Toll) or +1 646 558 8656 (US Toll) >>>> Meeting ID: 607 816 420 >>>> International numbers >>>> available: https://tennessee.zoom.us/zoomconference?m=fUOjmMyJwtMIeEsk8yo8CgLo3JR6yrTM >>>> >>>> Or an H.323/SIP room system: >>>> H.323: 162.255.37.11 (US West) or 162.255.36.11 (US East) >>>> Meeting ID: 607 816 420 >>>> Password: 463530 >>>> >>>> SIP: [email protected] >>>> <mailto:[email protected]> <mailto:[email protected]> >>>> Password: 463530 >>>> >>>> >>>> >>>>> On Mar 14, 2017, at 10:54, Aurelien Bouteiller >>>>> <[email protected] <mailto:[email protected]> >>>>> <mailto:[email protected]>> wrote: >>>>> >>>>> Hi all, >>>>> >>>>> We have the FTWG call scheduled for today. I’d like to debrief the >>>>> latest MPI forum activities, and continue the discussion on >>>>> converging localized and globalized recovery. >>>>> >>>>> I attach here the slide I used during the WG time. >>>>> <20170228-mpiforum-errwg.pptx> >>>>> >>>>> We may also want to decide the time for our future meeting based on >>>>> the doodle poll initiated by Wesley a while back. >>>>> http://doodle.com/poll/s5uvmpux4nc6ki4y#table >>>>> >>>>> === >>>>> Looking back at the notes from our last call in December, I believe >>>>> the TODO items are for Aurelien, Ignacio, and myself to flesh out the >>>>> three FT recovery proposals and then see how they would interact with >>>>> each other. >>>>> >>>>> * I believe Aurelien had some ideas about how to overcome some of the >>>>> problems raised at the last meeting. Aurelien, if you could put >>>>> together a slide or two that we could use for the discussion, that >>>>> would probably be helpful. >>>>> * I'm not sure of the status of Ignacio putting together some slides >>>>> for the reinit proposal. If I remember the meeting long ago in San >>>>> Jose, we just looked at a header. It might be nice to have something >>>>> a little more high level to point to. >>>>> * I still need to make the slides for the auto recovery strategy that >>>>> Martin proposed. >>>>> >>>>> Once that's done, we can see where these things interact and how >>>>> difficult it would be to support them together. >>>>> >>>>> Thoughts? >>>>> Wesley >>>>> _______________________________________________ >>>>> mpiwg-ft mailing list >>>>> [email protected] >>>>> <mailto:[email protected]> <mailto:[email protected]> >>>>> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft >>>> >>> >>> >>> >>> _______________________________________________ >>> mpiwg-ft mailing list >>> [email protected] <mailto:[email protected]> >>> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft >>> >> _______________________________________________ >> mpiwg-ft mailing list >> [email protected] <mailto:[email protected]> >> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft > _______________________________________________ mpiwg-ft mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft
participants (1)
Teranishi, Keita
