Re: [mpiwg-ft] [EXTERNAL] Re: FTWG Call Today
Ignacio, I see your point! Yes, this is a viable approach to make MPI_Reinit provide a bulk transaction mechanism by taking a function pointer of main_resilient. Todd’s example program is very clear. Like I did with Fenix, “reinitialization” of scientific library needs to be written separately. Fenix API provides callbacks (taking function pointers) to make it clean, and I think this can be done in MPI_reinit API, too. I agree on your another concern on signal handling. It should be a topic of the next meeting. Thanks, Keita On 3/15/17, 11:58 AM, "Ignacio Laguna" <[email protected]> wrote: Hi Keita, Yes and no :-) Sorry I was unclear in my explanation. There is the main function and we have a main_resilient version which is the one that contains most of the computation code. A pointer of this function is passed to a new MPI function, MPI_Reinit (so MPI_Init keeps its original semantics). Yes, some libraries call MPI_Init internally. I think that is not a problem as long as the main_resilient does not contain calls to library functions that initialize MPI. For example, main_resilient should not contain PETSc_initialize() or BLACS_Init(). Take a look at the C interface that Todd Gamblin wrote -- look at the example.c: https://github.com/tgamblin/mpi-resilience Ignacio On 3/15/17 11:22 AM, Teranishi, Keita wrote: > Ignacio, > > Does your technique creates replacement of main() (say main_reinit()) that makes a setjump() call inside? It’s interesting. Many scientific libraries make MPI_Init() call inside their initialization functions (such as PETSc_initialize() and BLACS_Init() ). I am not 100% sure how PETSC_Initialize() can return to the replacement of main(). Could you clarify the behavior of these functions maiking MPI_Init() call. > > BTW (including SC14 version), Fenix_init() is a macro that is expanded to three function calls. So the user cannot call outside main() ☹. > Fenix_preinit(); > Setjump(); > Fenix_postinit(); > > For this reason, when using PETSc with Fenix, I have to expose fenix_init() to main(). I cannot put inside petsc_initialize(). After all, I ended up wroting petsc_reintialize() to modify the contents created by petsc_initialize(). If your approach works, I can put Fenix_init() and petsc_reinitalize_fenix() inside petsc_initialize(), making the code much cleaner. > > Main() > { > petsc_initialize(); <= this is calling MPI_Init(); > Fenix_init(); > petsc_reinitialize_fenix(); > : > : > : > } > > Thanks, > Keita > > > > On 3/15/17, 10:46 AM, "[email protected] on behalf of Ignacio Laguna" <[email protected] on behalf of [email protected]> wrote: > > Hey Aurelien, > > Thanks! I understand the concern. > > For gloabal-restart models like Reinit (and I believe that for the SC14 > version of Fenix) this problem is solved by passing a reinit function > pointer to MPI, which it then calls after initialization (this function > is a replacement of main, and has the code that main originally > contained). Since this reinit function is kept in the stack (it never > returns), we can always long jump there. > > I think the main problem is that we cannot long jump from a signal > handler, or more specifically it is undefined according to the C > language. We would need to find another mechanism for long jumping after > a signal handler is called as a result of a failure notification. > > Ignacio > > > On 3/15/17 8:41 AM, Aurelien Bouteiller wrote: > > > > Hey Ignacio, > > > > Murali wanted to touch with you on that exact issue. The bottom line is > > that a setjump must be in the same stack frame as the long jump, which > > means that you can jump only to a function in which you are nested in. > > In many cases that means you can’t “hide” set jumps points in the > > library, as they have to be called in the application function context > > (so that they remain in your frame). > > > > Best, > > Aurelien > > > >> On Mar 14, 2017, at 18:15, Ignacio Laguna <[email protected] > >> <mailto:[email protected]>> wrote: > >> > >> Thanks for sharing the minutes. > >> > >> In the "scoped reinit-like approaches", there is the point of "still > >> subject to the longjmp complication". Can folks comment on what is the > >> issue with respect to setjump/longjump in global-restart approaches, > >> such as Reinit and/or Fenix? > >> > >> Thanks! > >> > >> Ignacio > >> > >> > >> On 3/14/17 1:49 PM, Aurelien Bouteiller wrote: > >>> Minutes for the call have been posted here: > >>> https://github.com/mpiwg-ft/ft-issues/wiki/2017-03-14 > >>> > >>>> On Mar 14, 2017, at 15:00, Aurelien Bouteiller <[email protected] > >>>> <mailto:[email protected]> > >>>> <mailto:[email protected]>> wrote: > >>>> > >>>> Hi there, > >>>> > >>>> Aurelien Bouteiller is inviting you to a scheduled Zoom meeting. > >>>> > >>>> Topic: MPI FT WG > >>>> Time: Mar 14, 2017 3:00 PM Eastern Time (US and Canada) > >>>> > >>>> Join from PC, Mac, Linux, iOS or > >>>> Android: https://tennessee.zoom.us/j/607816420?pwd=MuG6Nboy9%2Fo%3D > >>>> Password: beef > >>>> > >>>> Or iPhone one-tap (US Toll): +14086380968,607816420# or > >>>> +16465588656,607816420# > >>>> > >>>> Or Telephone: > >>>> Dial: +1 408 638 0968 (US Toll) or +1 646 558 8656 (US Toll) > >>>> Meeting ID: 607 816 420 > >>>> International numbers > >>>> available: https://tennessee.zoom.us/zoomconference?m=fUOjmMyJwtMIeEsk8yo8CgLo3JR6yrTM > >>>> > >>>> Or an H.323/SIP room system: > >>>> H.323: 162.255.37.11 (US West) or 162.255.36.11 (US East) > >>>> Meeting ID: 607 816 420 > >>>> Password: 463530 > >>>> > >>>> SIP: [email protected] > >>>> <mailto:[email protected]> <mailto:[email protected]> > >>>> Password: 463530 > >>>> > >>>> > >>>> > >>>>> On Mar 14, 2017, at 10:54, Aurelien Bouteiller > >>>>> <[email protected] <mailto:[email protected]> > >>>>> <mailto:[email protected]>> wrote: > >>>>> > >>>>> Hi all, > >>>>> > >>>>> We have the FTWG call scheduled for today. I’d like to debrief the > >>>>> latest MPI forum activities, and continue the discussion on > >>>>> converging localized and globalized recovery. > >>>>> > >>>>> I attach here the slide I used during the WG time. > >>>>> <20170228-mpiforum-errwg.pptx> > >>>>> > >>>>> We may also want to decide the time for our future meeting based on > >>>>> the doodle poll initiated by Wesley a while back. > >>>>> http://doodle.com/poll/s5uvmpux4nc6ki4y#table > >>>>> > >>>>> === > >>>>> Looking back at the notes from our last call in December, I believe > >>>>> the TODO items are for Aurelien, Ignacio, and myself to flesh out the > >>>>> three FT recovery proposals and then see how they would interact with > >>>>> each other. > >>>>> > >>>>> * I believe Aurelien had some ideas about how to overcome some of the > >>>>> problems raised at the last meeting. Aurelien, if you could put > >>>>> together a slide or two that we could use for the discussion, that > >>>>> would probably be helpful. > >>>>> * I'm not sure of the status of Ignacio putting together some slides > >>>>> for the reinit proposal. If I remember the meeting long ago in San > >>>>> Jose, we just looked at a header. It might be nice to have something > >>>>> a little more high level to point to. > >>>>> * I still need to make the slides for the auto recovery strategy that > >>>>> Martin proposed. > >>>>> > >>>>> Once that's done, we can see where these things interact and how > >>>>> difficult it would be to support them together. > >>>>> > >>>>> Thoughts? > >>>>> Wesley > >>>>> _______________________________________________ > >>>>> mpiwg-ft mailing list > >>>>> [email protected] > >>>>> <mailto:[email protected]> <mailto:[email protected]> > >>>>> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft > >>>> > >>> > >>> > >>> > >>> _______________________________________________ > >>> mpiwg-ft mailing list > >>> [email protected] <mailto:[email protected]> > >>> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft > >>> > >> _______________________________________________ > >> mpiwg-ft mailing list > >> [email protected] <mailto:[email protected]> > >> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft > > > _______________________________________________ > mpiwg-ft mailing list > [email protected] > https://lists.mpi-forum.org/mailman/listinfo/mpiwg-ft >
participants (1)
Teranishi, Keita
