[Mpi3-ft] Stabilization Updated & MPI_Comm_size question
So the Run-Through Stabilization proposal has been updated per our discussion in the working group meeting at the MPI Forum. The changes are summarized below: - Add a Legacy Library Support example - Clarify new error classes - Update the MPI_Init and MPI_Finalize wording to be simpler and more direct. - Fix wording of group creation calls versus communicator creation calls. https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/ft/run_through_stabilizati... One question that we discussed quite a bit during the meeting was the issue of the return value of MPI_Comm_size() when processes fail during launch. I attempted to capture the discussion in the room in the Open Question attached to the discussion of MPI_Init: https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/ft/run_through_stabilizati... Open question: If the user asks to start N processes on the command line, and only M processes were successfully launched (where M < N), then what should be returned from MPI_COMM_SIZE? The return value must be consistent across all alive members of the group. The issue is if it should return N or M. The feeling in the room was that since the MPI standard does not define the ability for the user to ask for a specific number of processes before initthen it is hard to define that this is the number it should be. So it is left to the implementation whether it is M or N. If it is M, then the user has other techniques to find out what it originally asked for (e.g., by passing it as a command line argument to the application itself). What do people think about the MPI_Comm_size issue? -- Josh ------------------------------------ Joshua Hursey Postdoctoral Research Associate Oak Ridge National Laboratory http://www.cs.indiana.edu/~jjhursey
participants (1)
Joshua Hursey
