Re: [mpiwg-ft] MPI_Comm_revoke behavior
This was raised as a concern at SC be an expert in the field, and specifically the issue of preserving rank I'd. We just need to follow up and ensure there is not a misunderstanding. Rich ------Original Message------ From: Wesley Bland To: MPI WG Fault Tolerance and Dynamic Process Control working Group Cc: MPI WG Fault Tolerance and Dynamic Process Control working Group ReplyTo: MPI WG Fault Tolerance and Dynamic Process Control working Group Subject: Re: [mpiwg-ft] MPI_Comm_revoke behavior Sent: Dec 6, 2013 9:08 AM Rich, This is something we've discussed many times on the con calls and mailing list, but we can discuss it on Monday as well. Aurélien will also be presenting slides during the FT plenary time demonstrating sample use cases. We haven't yet come up with something that we'll be excluding with the current proposal. Wesley On Dec 6, 2013, at 7:47 AM, Richard Graham <[email protected]> wrote: I would disagree with your characterization of the previous approach as anything but minimalistic. Let’s talk about this in the WG slot on Monday. I have to say that in some way I totally missed the point that this is intended to “be it”, so need to carefully re-evaluate the proposal in that light. My main concern is that the standard is supposed to provide a means for supporting a broad range of FT methodologies on top of this. Need to make sure that some of the approaches people do want to take are being blocked. Also, concern had been expressed that the resulting behavior will prevent many users from using it, so need to talk through these issues (I will say that the behavior described to me is a show stopper for many users, so need to make sure there is not a misunderstanding). Rich From: mpiwg-ft [mailto:[email protected]] On Behalf Of George Bosilca Sent: Thursday, December 05, 2013 11:38 AM To: MPI WG Fault Tolerance and Dynamic Process Control working Group Subject: Re: [mpiwg-ft] MPI_Comm_revoke behavior On Dec 5, 2013, at 15:14 , Richard Graham <[email protected]> wrote: [rich] the original intent was to allow for full restoration of communicators after failure, with minimal impact on those ranks that did not fail (don’t want to get into what that means now …). Those goals were reduced for pragmatic reasons. The goals were not reduced, ULFM is a completely new approach based on a pragmatic design. To emphasize what Wesley suggested, ULFM is not an all-encompassing solution (unlike previous proposals). Instead is a __minimalistic__ set of building blocks for stabilization and recovery allowing the construction of more complex FT mechanism. So far, the exploration of such complementary FT approaches have remained in the real of research, outside the WG
participants (1)
Richard Graham
