Re: [Mpi3-ft] MPI_Comm_validate_all
Le 16 f�vr. 2011 � 16:45, Graham, Richard L. a �crit :
You can't guarantee all will return, but you can guarantee that those who do, will return the same value. So you will get the status just before the call - which is the intent of this call.
Rich
To be clear: (all living processes return the same error) XOR (all living processes return SUCCESS and the lists are the same) -> Is it what this paragraph intended to say? -> The processes that don't return: are they dead? Or blocked in this call forever (hence, as useful as a dead processor)? I'm saying that - it is possible to implement these semantics, assuming a failure detection mechanism. - it is necessary to have these semantics to have a collective repair, and allow the application to use blocking calls, like MPI_recv, after such a validation. Thomas
On 2/16/11 3:49 PM, "Darius Buntinas" <[email protected]> wrote:
MPI_Comm_validate_all, according to the proposal at [1], must "either complete successfully everywhere or return some error everywhere." Is this possible to guarantee? What about process failures during the call? Consider the last message sent in the protocol. If the process sending that message dies just before sending it, the receiver will not know whether to return success or failure.
I think that the best we can do is say that the outcount and list of collectively-detected dead processes will be the same at all processes where the call completed successfully.
Or is there a trick I'm missing?
Thanks, -d
[1] https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/ft/run_through_stabiliza tion#CollectiveValidationOperations _______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
participants (1)
Thomas Herault
