Re: [Mpi3-ft] Communicator Virtualization as a step forward
Such statements are way to broad to be true. In fact it depends on what recovery mode was used. Please read the document I sent few emails ago, to see all the capabilities that FT-MPI provided. I make this statement because the FT-MPI model requires all processes to participate in recovery. At the very least, they need to participate in recreating communicators. This may become quite bad if we're using millions of processes. The problem I have is that this is a property of the model, not one implementation of it.
Again this is not true. First, one will need a kind of database to store this information (distributed or centralized) that came with its own scalability and cost problems. In addition, in the context of
Good point. The scalability and cost problems will absolutely need to be studied. However, as Thomas also pointed out, layering the current API on top of FT-MPI will be complex and will have very different performance properties, making it useless for such a study.
recovery the new processes will have to retrieve this information and let everybody else know not only their new contact information but the fact that they are back in the specified communicator. Unfortunately, this is [again] _NOT_ a local operation. The fact that you seems to plan to delegate these problems to the runtime environment, doesn't make it local nor more scalable.
You're right, any implementation would need to do a bunch of additional communication operations in order to support the "local rejoin" API, making it not truly local. However, the key difference is that in FT-MPI the recovery must employ a series of global collective operations that require all processes to synchronize. In contrast, runtime support for the local rejoin option is much less coupled. When a process sends a message to another process, it will need to attach the receiver's expected rank in MPI_COMM_WORLD to the message. If the receiver exists and has the right rank, message delivery occurs fine. If not, the sender gets an error and needs to ask the runtime environment for the correct physical address for the given receiver rank. This system involves probably as much overall communication as the everybody-synchronize approach but since the communication is decoupled, it will have a much smaller hit on performance. One thing I don't know is how to do the above for puts and gets. Is it possible for RDMA hardware to do any verification of the destination process? Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected]
participants (1)
Greg Bronevetsky
