Re: [MPI3 Fortran] Proposing changes to Fortran 2008
On Mar 20, 2008, at 11:13 AM, Craig Rasmussen wrote:
Yes, but the same size hole would exist for the "companion" C struct as well. So however you calculate stride information for C would work for an interoperable derived type in Fortran as well. Suppose foo were,
struct foo { char a; char b; int i; char c; char d; }
Ok, but you said everything in Fortran had to be contiguous. With a hole, by definition, it's not contiguous (and, per my other mails, you can be much more arbitrary, such as skipping the "b" field in the struct above). Does Fortran have a different definition of "contiguous" than C? :-)
Don't you have to worry about the C compiler reordering the elements of foo?
With C++, perhaps. With C, no. Regardless, if you construct the MPI datatype (map) at run-time, then MPI will get the Right values for offsets into the memory map because you actually measure the distances/offsets at run-time (vs. compile- time). -- Jeff Squyres Cisco Systems
participants (1)
Jeff Squyres
