Re: [MPIWG Fortran] ticket 351
Hi Jeff, I admit that the Fortran standard is (intentionally) vague about what constitutes a "command line". However, I tried the 5 compilers I have available (Cray, Intel, PGI, gfortran, Pathscale) with a simple program that prints argument 0 == the "command name by which the program was invoked", and in all cases the launcher text (aprun -n1 ) was ignored and the program printed "./a.out". Not conclusive, but suggests that the vendors have figured out what the right "quality of implementation" action is here. If there are examples to the contrary, I'd be interested in knowing about them. Cheers, Bill On 10/22/13 10:12 AM, N.M. Maclaren wrote:
On Oct 22 2013, Bill Long wrote:
2) I don't really see the point of this at all. The user can just call the native Fortran intrinsics directly. Why should there be a duplicate version that starts with MPI_ ? I would suggest, instead, that you just add a note in the spec (advice to users) point out that Fortran programmers can access the command line arguments using the language intrinsics. Maybe someone can convince me this is not adequate, but I've been using those intrinsics with parallel programs for some time and they work just fine.
I assume that the desire for this is to support the systems which do not use a mpiexec/mpirun command, but fire up MPI directly, as IBM poe does.
However, I have always felt that the original C approach was a horrible hack, just as having C's argument list (and arguments) writable is. There were good reasons at the time but, given that Fortran has done without it with little to no trouble for so long, I agree with Bill.
Regards, Nick Maclaren.
_______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
-- Bill Long [email protected] Fortran Technical Support & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc./Cray Plaza, Suite 210/380 Jackson St./St. Paul, MN 55101
participants (1)
Bill Long
