Re: [MPIWG Fortran] [mpiwg-abi] MPI_Fint in the ABI
The problem with that is here: int MPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status) You are right that pass-by-value scalars are fine if we bound the range to make truncation work, but pointers do not allow this. Jeff
On 18. Aug 2023, at 12.45, William Robert Williams <[email protected]> wrote:
Is there a reason not to mix 1 and 3: MPI_Fint is a fixed C type, decouple it from INTEGER, and require Fortran handles to stay within the smaller of INTEGER and MPI_Fint in order to be valid? (Yes, backwards compatibility, but that’s probably gone regardless in order to ABI-specify MPI_Fint.) This way an implementation can have larger or smaller INTEGERs vs. C ints as it desires, as long as it guarantees that they are valid MPI_Fints as well, and Fint stays fixed.
19.3.4 will need revision no matter what we decide.
—Bill
On 18. Aug 2023, at 11:35, Jeff Hammond <[email protected] <mailto:[email protected]>> wrote:
MPI_Fint is part of the C ABI. It is strictly used in MPI C code to allow conversion of Fortran handles to C handles and vice versa. It must be part of the C ABI for the f2c/c2f functions to be part of the C ABI.
For example, from 19.3.4:
C binding MPI_Comm MPI_Comm_f2c(MPI_Fint comm) MPI_Fint MPI_Comm_c2f(MPI_Comm comm)
MPI_Fint is not part of the Fortran API or ABI, because Fortran handles are defined to be INTEGER (or an INTEGER inside of a type(MPI_Handle) object).
Jeff
On 17. Aug 2023, at 17.52, Zhou, Hui <[email protected] <mailto:[email protected]>> wrote:
I haven't gone through all the use cases, but my current opinion is, it is really a Fortran binding issue and should be left out of C ABI.
Hui
From: mpiwg-abi <[email protected] <mailto:[email protected]>> on behalf of Erik Schnetter <[email protected] <mailto:[email protected]>> Sent: Thursday, August 17, 2023 9:35 AM To: Jeff Hammond <[email protected] <mailto:[email protected]>> Cc: mpiwg-abi <[email protected] <mailto:[email protected]>>; MPI Forum <[email protected] <mailto:[email protected]>> Subject: Re: [mpiwg-abi] MPI_Fint in the ABI
Jeff
As per the Fortran standard, the sizes of integer and real need to be the same. In practice this means that integers have 4 bytes. If someone chooses to change this – either changing the size of real as well or not – then they are breaking the Fortran standard, and probably know what they are doing, and are aware of the various incompatibilities and problems this will introduce. I would thus suggest keeping things simple for the common case. I would not expect there to be some code that interoperates with Fortran, and which is unaware of the Fortran integer size and still expects to get things right. People will either assume that integer = int, or will know the Fortran ABI details.
In the MPI ABI we assume that the caller knows sizeof(int) and sizeof(void*), and I would also assume that they know sizeof(integer). I would keep `MPI_Fint` a fixed type.
To cover all bases I also suggest that we provide a global constant struct with as much ABI information as we can think of, such as
const struct MPIABI_info_t { int32_t MPIABI_version_major, MPIABI_version_minor; int32_t sizeof_bool; int32_t sizeof_char; int32_t sizeof_short; int32_t sizeof_int; int32_t sizeof_long; int32_t sizeof_long_long; int32_t sizeof_float; int32_t sizeof_double; int32_t sizeof_long_double; int32_t sizeof_void_p; int32_t sizeof_logical; int32_t sizeof_integer; int32_t sizeof_real; int32_t sizeof_char; } MPIABI_info;
This information would not be necessary to use the ABI, but it will be convenient to check assumptions. Unsupported types report a size of -1.
This struct can be extended in the future.
-erik
On Wed, Aug 16, 2023 at 4:09 AM Jeff Hammond <[email protected] <mailto:[email protected]>> wrote:
As we all know, Fortran users are permitted to change the size of INTEGER with compiler flags. This creates a problem for the MPI C ABI.
I have considered three options and would like your opinions on them:
1. MPI_Fint is defined to be a C int in the standard ABI. This means MPI implementations that elect to provide an ILP64 MPI Fortran ABI on an I32LP64 system, for example, must not call this an implementation of the standard ABI.
This would make a lot of things easier, but it might cause problems in the rare cases where users are using ILP64 in Fortran and using C code that actually uses MPI_Fint.
2. MPI_Fint ceases to be a compile-time fixed type in the standard ABI. The C code that uses MPI_Fint must make an MPI library call to figure out the size and do all of the necessary things to call the correct size.
3. MPI_Fint is not a fixed size but the standard ABI specifies that Fortran handle values must always fit into the range of a C int and we rely on the pass-by-value behavior of all the f2c/c2f APIs to behave properly when they are truncated.
This is my preference but it breaks Example 19.11 in a serious way, because that user code makes use of a MPI_Fint pointer. However, this code isn't standard-compliant and relies on universal but non-standard argument passing conventions in Fortran. Writing a standard-compliant interface from Fortran to C - by doing the cast to INTEGER(kind=c_int) in Fortran - would resolve this.
Example 19.11 is awful (https://github.com/mpi-forum/mpi-issues/issues/739) but it is nonetheless important to instruct users that if Option 3 is implemented, they need to do the casting to INTEGER(kind=c_int) and know that this is safe with the standard ABI.
None of these options is perfect. I'm not sure how much code is even impacted by MPI_Fint so it's hard to know which option breaks the most stuff, although Option 2 seems the least desirable in any case.
Jeff
-- Jeff Hammond [email protected] <mailto:[email protected]> http://jeffhammond.github.io/ -- mpiwg-abi mailing list [email protected] <mailto:[email protected]> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-abi
-- Erik Schnetter <[email protected] <mailto:[email protected]>> http://www.perimeterinstitute.ca/personal/eschnetter/ -- mpiwg-abi mailing list [email protected] <mailto:[email protected]> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-abi
-- Bill Williams Wiss. Mitarbeiter ZIH-IAK, TU-Dresden Falkenbrunnen, Room 009 Chemnitzer Straße 50 01187 Dresden Phone: +49 351 463-39976 e-mail: [email protected] <mailto:[email protected]> He/him/his
participants (1)
Jeff Hammond
