Re: [MPI3 Fortran] (j3.2006) (SC22WG5.3917) (SC22WG5.3909) [ukfortran] [MPI3 Fortran] MPI non-blocking transfers
Van Snyder wrote:
On Fri, 2009-01-23 at 12:44 -0800, Bill Long wrote:
The problem is solved for asynchronous I/O in Fortran by exactly the same means. The solution relies on C1239 and C1240 [299:12-19] in 09-007. If you violate either of these constraints, your program will be rejected by the compiler and you have to fix it.... If we plan to base a solution on asynchronous (or volatile) for MPI, then the solution is exactly the same as for asynchronous I/O in Fortran.
Since solutions exist for asynchronous Fortran I/O, which is indistinguishable from MPI hiding in an external procedure, why are we having this conversation?
Just write an extra layer to get at MPI_wait, having an assumed-shape buffer dummy argument with the ASYNCHRONOUS attribute and without the CONTIGUOUS attribute. Since the buffer dummy won't be referenced, make the procedure external, or better yet, write it in C, so a clever optimizer won't inline it, notice the buffer isn't used, and then move accesses to the buffer across the remaining reference to MPI_wait, which is the present problem.
The copy-in/copy-out problem does not affect MPI_wait. There's no argument to copy anyway. Copy-in/copy-out is a serious problem for the earlier call to MPI_Isend, etc. where you do not want the copy temp being the buffer MPI sees, since it will get deleted when the call returns (which is before MPI is done with it.) This continues with any subsequent call to other routines that have the buffer as the argument, because a copy-out runs the risk of overwriting the buffer with the wrong values. Cheers, Bill -- Bill Long [email protected] Fortran Technical Support & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc., 1340 Mendota Heights Rd., Mendota Heights, MN, 55120
participants (1)
Bill Long
