Re: [MPIWG Fortran] Data type of F08 subarray
On Tue, May 13, 2014 at 2:00 PM, Bill Long <[email protected]> wrote:
On May 13, 2014, at 12:44 PM, Junchao Zhang <[email protected]> wrote:
On Tue, May 13, 2014 at 11:56 AM, Rolf Rabenseifner <
REAL s(100) MPI_SEND(s (1:100:5) , 3, dtype, ...) dtype can only be MPI_REAL. In other words, dtype is kind of redundant here since the type map is actually specified by the subarray.
Right. The descriptor for the first argument has a member whose value is a type code. In principal the library could verify this is compatible with the data type handle supplied as the third argument, and issue an error if not. Perhaps in a “debug” mode.
No, if dtype is a vector then it is applied to a virtual contiguous array that consists of s(1), s(6), s(11) …
dtype is not a vector, is it? That argument is a scalar of type TYPE(MPI_DATATYPE). At least that is what the interface says.
Rolf meant dtype is an MPI datatype created by MPI_Type_vector. For this case, I will have two datatypes, one from the MPI_Datatype argument, the other from the choice buffer itself. It is hard to implement that. Perhaps it is useless since it obscures the program.
Cheers, Bill
That is nasty. Then I will have two data types. I even can not assume
any relationship between the two types. I have to allocate a scratch buffer for the virtual contiguous array in MPI_ISEND etc, do memory copying and then free the buffer in MPI_WAIT. I'm not sure one can implement it efficiently.
----- Original Message -----
From: "Junchao Zhang" <[email protected]> To: "MPI-WG Fortran working group" <[email protected]> Sent: Tuesday, May 13, 2014 6:23:08 PM Subject: Re: [MPIWG Fortran] Data type of F08 subarray
Thanks, Rolf. And I feel there is a jump from contiguous subarray to non-contiguous subarray.
For contiguous subarray, such as
REAL s(100)
MPI_SEND(s(2:50), 3, dtype, ...) s only gives the start address. dtype can be anything, e.g., either a basic type or a derived type created by MPI_Type_vector() etc.
For non-contiguous subarray, such as
--Junchao Zhang
On Tue, May 13, 2014 at 10:20 AM, Rolf Rabenseifner < [email protected] > wrote:
Dear Junchao,
MPI-3.0 p25:7-8 describes only communication with language type of the buffer argument matches to the MPI datatype used in the datatype argument. Same p83:36-37.
Therefore, the answer is no and the compiler cannot detect a mismatch beteen language buffer specification and MPI datatype specification.
I hope my answer could help.
Best regards Rolf
From: "Junchao Zhang" < [email protected] > To: "MPI-WG Fortran working group" < [email protected] > Sent: Tuesday, May 13, 2014 5:08:30 PM Subject: [MPIWG Fortran] Data type of F08 subarray
p626 of MPI-3.0 gives such an example
REAL s(100), r(100) CALL MPI_Isend(s(1:100:5), 3, MPI_REAL, ..., rq, ierror)
All nonblocking MPI functions behave as if the user-specified elements of choice buffers are copied to a contiguous scratch buffer in the MPI runtime environment. All datatype descriptions (in the example above, “3, MPI_REAL”) read and store data from and to this virtual contiguous scratch buffer ...
Here, data type of s(100) match with MPI_REAL, so everything is fine. But I want to know if MPI permits mismatched types, for example, can s(100) be an integer array? If the answer is no, then compilers can not detect this error ; if yes, then it is hard to implement that. To avoid memory copying to a scratch buffer, I want to use MPI datatypes. But if I have two types, one is given by the choice buffer itself, the other is given by the MPI_Datatype argument, how could I do that?
Any thoughts?
Thanks
--Junchao Zhang _______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) _______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
Bill Long [email protected] Fortran Technical Suport & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc./ Cray Plaza, Suite 210/ 380 Jackson St./ St. Paul, MN 55101
participants (1)
Junchao Zhang
