Re: [MPI3 Fortran] [Mpi-comments] MPI 3.0:Fortran 2008 interface - issue with the LOGICAL kind
Hi all, I am trying to catch up with the various threads on this (sorry, last week was hectic and I didn't get to all emails). I have to admit that I am still confused why there is a problem, but we can clarify this during a phone call or during the march meeting. However, doesn't not doing BINDC create a problem, since I now have to again deal with the no/one/two underscore issue? This sounds like a bad interface design to me, especially when we starting mixing things. Martin On Mar 4, 2013, at 9:47 AM, Rolf Rabenseifner <[email protected]> wrote:
Dear all,
I forget to say thank you to all of you who helped to solve this hard problem. It was a really helpful discussion. It is a pity that we could not keep the BIND(C) for all routines in mpi_f08, which was one goal with mpi_f08 and TS 29113.
In my proposal #364, we have to remove BIND(C) from - the 30 normal MPI routines with LOGICAL arguments, - the 9 MPI routines with callbacks in the argument list, - and 10 predefined callbacks, i.e., from 49 out of 357 MPI routines.
I do not see a better solution that can be done by the MPI Forum. Better solutions are still possible for the 30 normal routines and/or for the 9 routines with callback-arguments as soon as the Fortran standard will include some additions and those additions are provided by the compilers - but if this will happen then it will not happen soon.
It was luck that all routines with buffer arguments do not have also a LOGICAL argument.
Best regards Rolf
------------------ Malcolm and all MPI implementors, and TOOLS implementors,
First Malcolm, thank you for your helpful answer. After all the discussion, the MPI-3.0 errata decision is very simple: Remove BIND(C) everywhere where LOGICAL is around.
I did it in the ticket #364 https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/364
I hope that one of the implementors with Fortran knowledge goes through my proposal and returns an "okay" as a review on the ticket.
The major changes: - BIND(C) removed on all callback abstract interfaces. - BIND(C) removed on all predefined callbacks. - Creating a new routine group "MPI_TEST" for all MPI routines with LOGICAL arguments, except MPI_OP_CREATE, which is already in an own group. - Telling that the routines in the groups MPI_TEST, MPI_OP_CREATE, MPI_REGISTER_DATEREP, and MPI_COMM_KEYVAL_CREATE cannot be implemented with BIND(C) in Fortran 2008 + TS 29113 and earlier.
TOOLS implementors should be aware that I added this new routine group.
Best regards Rolf
----- Original Message -----
From: "Malcolm Cohen" <[email protected]> To: "MPI-3 Fortran working group" <[email protected]> Sent: Monday, March 4, 2013 3:56:50 AM Subject: Re: [MPI3 Fortran] Fwd: [Mpi-comments] MPI 3.0:Fortran 2008 interface - issue with the LOGICAL kind
(B1) Is it possible, that a BIND(C) routine has a dummy argument that is a non-BIND(C) ABSTRACT INTERFACE procedure argument?
That is not possible: all dummy arguments of a BIND(C) routine must be interoperable - for procedures that requires BIND(C).
It would be reasonable to extend C_FUNLOC and C_F_PROCPOINTER to permit non-interoperable procedures, similarly to how we permit non-interoperable variables in C_LOC and C_F_POINTER. Then the argument could be C_FUNPTR (by value). I don't know whether this would help you though.
(B2) Do we have any problem with the TYPE(C_PTR), VALUE dummy arguments in the ABSTRACT INTERFACE MPI_User_function on MPI-3.0 page 183 line 45 - page 184 line 3 if the we remove the BIND(C) from this ABSTRACT INTERFACE (i.e. on page 183, line 47).
No problem.
Cheers, -- ................................Malcolm Cohen, Nihon NAG, Tokyo.
_______________________________________________ mpi3-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-fortran
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307)
________________________________________________________________________ Martin Schulz, [email protected], http://people.llnl.gov/schulzm CASC @ Lawrence Livermore National Laboratory, Livermore, USA
participants (1)
Schulz, Martin
