Re: [MPIWG Fortran] Draft MPI-3 Errata
Dear Bill, thank you for your fast integration. The following small corrections are needed: p1:28-29 Please substitute "to several declarations. Those must also be removed." by "to a routine declaration. This change is now removed." Reasons: - I tried to always say that the removal of BIND(C) is only in "routine" declarations. The BIND(C) handles and status type in mpi_f08 stay BIND(C). - It was only MPI_Comm_create_group() - i.e., one routine. In all other routines in the old errata, the original MPI-3.0 had already the BIND(C), i.e., it was not added by the old errata. - The note is about a previous errata document. The second sentence should tell, that in the current version, this bug is removed: "This change is now removed." p2:16-18 Please change "specific procedure" into "linker". Reason: The "old text" you saw, was already MPI-3.0 + ticket 388, And not the really existing MPI-3.0 text. My apologies for this confusion. p3:17-23 - Please remove, because already part of p2:11-25. p4:29-35 - Please remove, because already part of p2:11-25. p5:33-39 - Please remove, because already part of p2:11-25. p18:5 - Please remove the word "SUBROUTINE". (The upper case Routine Name is okay, because it is a callback "constant".) p18:21 - Please remove the word "SUBROUTINE". p18:1-28 - Please move it to the end of the errata. (due to the errata are sorted by location). Best regards Rolf ----- Original Message -----
From: "William Gropp" <[email protected]> To: "MPI-WG Fortran working group" <[email protected]> Sent: Friday, September 20, 2013 5:05:14 PM Subject: [MPIWG Fortran] Draft MPI-3 Errata Because it is so extensive and some of the items in the errata were superseded by this errata, I'd like to have the Fortran WG review the errata before I post it. Let me know if there are any errors to correct.
Note that the use of page numbers (which I have always felt was a mistake) leads to some misleading pointers, since the relevant material in section 17.1.5 is not on the first page of that section. Rather than correct that here, I'll recommend eliminating the use of page references in the text for MPI 3.1 and later.
Bill
William Gropp Director, Parallel Computing Institute Deputy Director for Research Institute for Advanced Computing Applications and Technologies Thomas M. Siebel Chair in Computer Science University of Illinois Urbana-Champaign
_______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307)
participants (1)
Rolf Rabenseifner
