[MPI3 Fortran] ASYNCHRONOUS and non-blocking communication
Hello, Following some recent discussions on J3 I have written a paper on modifications needed to make the ASYNCHRONOUS attribute work with non-blocking communication. Craig already pointed out that VOLATILE can be used as well: REAL :: buffer(100) BEGIN BLOCK VOLATILE :: buf err = MPI_Irecv(buf, ..., req) . . err = MPI_Wait(req, ...) END BLOCK This has the unwanted side-effect that it requires BLOCK (so the whole transfer needs to occur within one scoping unit) to enable optimizations outside of the region where the asynchronous data transfer occurs. It seems much better if the already existing mechanisms for Fortran asynchronous I/O apply to user-defined I/O as well. The paper is below. I know it is a little technical in the edits, but please look over it and comment. If the MPI-3 Fortran group wishes to officially endorse it that might help. Even if this is not a timely solution, in the sense that it requires the SYNC MEMORY statement which is new in Fortran 2008 due to the addition of explicit parallelism to the language (coarrays), I still think it is good to have it. The Fortran meeting is in August so this paper should be submitted by the end of July. Thanks, Aleks -------------- To: J3 From: Aleksandar Donev Subject: User-specified ASYNCHRONOUS I/O Date: 6/13/2008 Several important libraries have routines for asynchronous data transfer, for example, MPI's non-blocking communication routines. The use of these routines is essentially identical to asynchronous I/O within Fortran 2003, however, the ASYNCHRONOUS attribute only applies to the standard-specified asynchronous I/O. The VOLATILE attribute may be used to signal to the compiler that a variable may be modified asynchronously by an external mechanism, however, this disables all optimizations involving the variable, which is not needed. In particular, in good programs the variable will not be referenced or defined while asynchronous data transfer is possibly occuring (this is an explicit restriction in the MPI standard), just as required in F2003 for variables involved in async I/O. It is therefore useful to extend the semantics of the ASYNCHRONOUS attribute to also apply to user-defined I/O. This was difficult to do in Fortran 2003 because the issues of memory consistency were hard to specify. However, the same kind of asynchronous data transfer and memory consistency issues occur with co-arrays, and we now have the segment model and SYNC MEMORY to lean on. I therefore consider this issue to be integration and appropriate for immediate incorporation into Fortran 2008, especially given the long-existing demand for it from the MPI community. I propose that the following modification be made to the F2008 standard: We should explicitly allow a variable with the ASYNCHRONOUS attribute to be modified or examined by means external to the processor, similarly to VOLATILE variables. If such a variable is modified or examined externally during a segment, that variable must not be referenced or define during that segment. Details are in the edits below. This simple modification solves an existing problem with MPI non-blocking transfer, namely, the need to prevent movement of code across calls to MPI_Wait. The programmer can use SYNC MEMORY to indicate to the compiler that ASYNCHRONOUS variables may be affected and therefore old copies in registers should be discarded and new values written to memory. This is exactly as for coarrays and TARGETs (which may be modified by other images) and also just like SYNC MEMORY needs to be put around external synchronization routines such as MPI_Barrier (see Note 8.39). Also note that the ASYNCHRONOUS attribute solves another vexing problem with MPI non-blocking transfer, namely, that of copy in/out. The existing rules we have now specify that if both the dummy and the actual have the ASYNCHRONOUS attribute, no copy in/out can occur because either the dummy has to be assumed-shape or the actual has to be simply-contiguous. It would be nice if we could say that explicitly in the standard (not proposed here because I do not know how to word it). Note that the use of SYNC MEMORY will lead to lots of code segments like this: SYNC MEMORY CALL MPI_Wait(request,...) ! Complete communication SYNC MEMORY or SYNC MEMORY CALL MPI_Barrier(comm) ! If used to synchronize images SYNC MEMORY I think it would be a benefit to programmers to give them syntactic sugar to do this without requiring rewriting existing codes or writing wrappers. It could be achieved through a SYNC procedure attribute, which cannot be combined with PURE and is not a procedure characteristic. A call to a procedure with the SYNC attribute implies a SYNC MEMORY both before and after the call. I do not provide edits for this but I hope it can be voted on. --------------------- Examples: -------- Example 1: REAL, ASYNCHRONOUS :: buffer(100) SYNC MEMORY ! This is not really necessary in practice, it should be added err=MPI_IRecv(buffer,...,request,...) ! The dummy buffer has the ASYNC attribute ... ! Code not involving buffer but buffer may be modified outside err=MPI_Wait(request,...) SYNC MEMORY WRITE(*,*) buffer -------- Example 2: REAL..., ASYNCHRONOUS :: buffer1, buffer2, ... CALL PrepareNonBlocking(buffer1, buffer2, ...) ! Build internal pointers etc. ! This may take some time to initialize, but is done only once ! No copy in/out will happen if buffers are simply-contiguous ! and the interface has ASYNCHRONOUS on the dummies .... buffer2=... SYNC MEMORY CALL BeginNonBlocking() ! Start async transfer .... ! Cannot reference buffers within this segment .... ! This may span across many procedure calls or even scoping units CALL WaitNonBlocking() SYNC MEMORY WRITE(*,*) buffer1 --------------------- Edits: [88:p1] Clause 5.3.4 on the ASYNCHRONOUS attribute: Add to the end of the first sentence: ", or a variable that may be referenced, defined, or become undefined, by means not specified by the program." {Note that I specifically do not want to allow pointer or association status to be changed asynchronously, as we do for VOLATILE.} [88:p2] Clause 5.3.4. Rewrite para 2: The base object of a variable shall have the ASYNCHRONOUS attribute in a scoping unit if the variable appears in an executable statement or specification expression in that scoping unit and any statement of the scoping unit is executed while -the variable is a pending I/O storage sequence affector (9.6.2.5), or -the variable is referenced, defined, or become undefined, by means not specified by the program and the base object does not have the VOLATILE attribute in that scoping unit {Note: The second item may be stronger than we want since it requires either VOLATILE or ASYNCHRONOUS to be specified. Does this disallow existing threaded programs?} {Note: These rules are meant to be analogues of the rules in 9.6.4 for Fortran async I/O.} [88:p3+] Add a new paragraph after para 3: If a variable has the ASYNCHRONOUS attribute but does not have the VOLATILE attribute, then: -If it is referenced by means not specified by the program during the execution of a segment, then it shall not be defined or become undefined in a statement executed during that segment. -If it is defined or becomes undefined by means not specified by the program during the execution of a segment, then it shall not be referenced, defined, or become undefined in a statement executed during that segment, or become associated with a dummy argument that has the VALUE attribute during that segment. [88:NOTE 5.4] Clause 5.3.4. Add a new sentence before the last sentence of Note 5.4: "The ASYNCHRONOUS attribute should also be used to specify variables that are involved in user-defined asynchronous data transfer, such as asynchronous I/O or communication performed by an external library." [88:] Clause 5.3.4. Add a new Note 5.4+: "The difference between the VOLATILE and ASYNCHRONOUS attributes is that the processor may optimize the execution of a segment assuming that all asynchronous data transfer happens due to means specified by the program. After a new segment begins, the Fortran processor should reload the most recent value of an asynchronous object from memory when a value is required. Likewise, when a segment ends, the processor should store the most recent Fortran definition in memory. It is the programmer's responsibility to manage any interaction with non-Fortran processes and to use SYNC MEMORY to delimit segments and thus inform the processor to disable certain optimizations. It is also the programmer's responsibility to only reference or define the variable in segments in which it is not being defined or referenced by non-Fortran processes. For example: INTERFACE SUBROUTINE MY_WRITE(var, n_bytes, id) REAL, INTENT(IN), ASYNCHRONOUS :: var(*) INTEGER, INTENT(IN) :: n_bytes INTEGER, INTENT(OUT) :: id END SUBROUTINE SUBROUTINE MY_WAIT(id) INTEGER, INTENT(IN) :: id END SUBROUTINE END INTERFACE REAL :: buffer(100) INTEGER :: id buffer=... ! Definition SYNC MEMORY ! Segment boundary ! No copy shall occur in this call since buffer is simply-contigous: CALL MY_WRITE(buffer, SIZE(buffer)*(STORAGE_SIZE(buffer)/8), id) ! Statements not referencing or defining buffer CALL MY_WAIT(id) ! Complete the asynchronous I/O SYNC MEMORY ! Segment boundary buffer=... ! Definition
participants (1)
Aleksandar Donev
