Re: [MPIWG Fortran] ticket 351
MPI implementations today are remarkably standardized w.r.t. process launching such that standard arguments are handled prior to MPI_Init. However, there have been times where that was not the case. Can you check what the Cray T3D does w.r.t. arguments passed to the host node appearing on the compute nodes? :-) More seriously, does Fortran 2008 require that arguments passed to the invocation of mpirun (or equivalent) appear at every process in a multi-process MPI program? Jeff Jeff On Mon, Nov 9, 2015 at 8:56 AM, Bill Long <[email protected]> wrote:
On Nov 9, 2015, at 8:56 AM, Jeff Hammond <[email protected]> wrote:
On Mon, Nov 9, 2015 at 6:37 AM, Bill Long <[email protected]> wrote:
On Nov 9, 2015, at 8:24 AM, Jeff Hammond <[email protected]> wrote:
Did you read the ticket? We need this for the same reason MPI_Init()
takes argc/argv even though C main() already has them.
But the C standard does not implicitly assume every program is parallel.
Correct. Nor can MPI assume that argc/argv will magically appear on the
compute nodes when the job is launched from somewhere else.
Agreed. My point is that Fortran is not the same as C.
While it may be true that process managers are magically fixing
argc/argv, this is not guaranteed by any standard.
The Fortran standard is intentionally vague to allow for environments where there is no command line, but rather (for example) the code starts executing by clicking a graphic button on the screen. The standard is likely to not include specific words about program launchers that might turn into bit rot in the future. If your favorite compiler returns the launcher text as part of the command line, complain.
Complaining is fun, but has no teeth without a standard. Many vendors are quite strict about standards and reject feature requests that improve user experience if they lack justification in a standard. I can cite numerous vendors here…
The overriding intent of a language standard is portability. You would have poor portability of a code if moving it from one machine to another resulted in different command argument information from get_command or get_command_argument. The intention is that the routine return the command line arguments that the program knows about, not some cryptic stuff from aprun, srun, or mpirun. I did try all the compilers I have access to on a trivial code:
cat test.f90 program test character(1000) command integer length call get_command (command, length) print *, command(1:length) end program test
ftn test.f90 aprun -n1 ./a.out -x ./a.out -x Application 15961022 resources: utime ~0s, stime ~0s, Rss ~4176, inblocks ~4479, outblocks ~11453 module swap PrgEnv-cray PrgEnv-intel ftn test.f90 aprun -n1 ./a.out -x ./a.out -x Application 15961023 resources: utime ~0s, stime ~0s, Rss ~4176, inblocks ~2967, outblocks ~7756 module swap PrgEnv-intel PrgEnv-pgi ftn test.f90 aprun -n1 ./a.out -x ./a.out -x Application 15961025 resources: utime ~0s, stime ~0s, Rss ~4172, inblocks ~3038, outblocks ~8308 l> module swap PrgEnv-pgi PrgEnv-gnu ftn test.f90 aprun -n1 ./a.out -x ./a.out -x Application 15961026 resources: utime ~0s, stime ~0s, Rss ~4172, inblocks ~3031, outblocks ~8027
All of them produced the expected output (excluding the “aprun -n1” launcher text).
Perhaps we could add a Note in the Fortran standard explaining this, but it looks like vendors have already figured it out.
Cheers, Bill
While the new proposed routines are trivial to implement (assuming they
have the same arguments as the corresponding Fortran ones), they add to one of MPI’s most serious flaws - way to many routines already.
As you say, they are trivial to implement. The size of the standard is
an irrelevant argument. Users don't read what they don't need to read and users shouldn't be reading the spec most of the time anyways.
Jeff
Cheers, Bill
Jeff
On Mon, Nov 9, 2015 at 6:21 AM, Bill Long <[email protected]> wrote: Hi Jeff,
I don’t see the value of this. The Fortran intrinsics GET_COMMAND and
friends should already do what you want. Fortran programs are now presumed parallel. The intrinsics should know how to strip off the “launcher” part of the command line. At least that is how the Cray versions have worked from the beginning. Experiments are in order for other vendors, as a check.
Cheers, Bill
On Nov 9, 2015, at 8:13 AM, Jeff Hammond <[email protected]>
wrote:
we did a lot of work on
https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/351. do we intend to move forward this for MPI 4+? if yes, we need to migrate the trac ticket to a github issue.
jeff
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
Bill Long [email protected] Fortran Technical Support & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc./ Cray Plaza, Suite 210/ 380 Jackson St./ St. Paul, MN 55101
participants (1)
Jeff Hammond
