Re: [MPIWG Fortran] Type of MPI_Status
On Mar 17, 2014, at 5:00 PM, Craig Rasmussen <[email protected]> wrote:
On Mar 17, 2014, at 2:52 PM, Jeff Squyres (jsquyres) wrote:
On Mar 17, 2014, at 5:13 PM, Bill Long <[email protected]> wrote:
Try adding IMPLICIT NONE in the scope and see how well that works out for you. The argument to KIND is a variable or constant of intrinsic type. The result is the kind parameter value for that variable or constant. In your example, the result is the kind parameter value for the variable or named constant INTEGER. KIND does not take the name of a type as its argument. (And Fortran does not have reserved words, so INTEGER is a fine variable name.)
Craig owes Jeff a beer...
Crap, again? I keep forgetting which language I'm programming in. I checked this with gfortran and it worked (as it should, but not in the way I thought it would). That is why I originally suggested to Jeff it be
KIND(1)
(because the literal 1 is an integer), but he asked what the heck does that mean so I came up with an example that I thought was more clear (but was actually worse).
More important, 1 is of type *default* integer, which is the requirement here.
So this is Bill's suggestion (at least this is what I inferred from reading his email, if he recants on his suggestion, he should do so now :-)
implicit none integer :: integer integer, parameter :: ompi_int_kind = KIND(integer)
That would work, but looks like an entry in an obfuscated coding contest. Not recommended (at least by me) for code maintenance. Cheers, Bill
-craig
_______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
Bill Long [email protected] Fortran Technical Suport & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc./ Cray Plaza, Suite 210/ 380 Jackson St./ St. Paul, MN 55101
participants (1)
Bill Long
