Re: [MPI3 Fortran] Nonblocking MPI and Fortran temporary memory modifications
Hi all, this is an excellent basis for the necessary review (deadline March 31, 2011!) of TR 29113 (Version N1845) ftp://ftp.nag.co.uk/sc22wg5/N1801-N1850/N1845.pdf from http://www.nag.co.uk/sc22wg5/ I put Brain Smith from IBM also on the CC list. The cited papers can be found at http://www.j3-fortran.org/doc/year/09/09-235r2.txt and http://www.j3-fortran.org/doc/year/09/09-231.txt Goal of this "extend ASYNCHRONOUS" SV: extend ASYNCHRONOUS - invent new attribute - undefined: 8-2-3 is that the following code is a correct code and allows that the MPI library internally used DMA, the NIC, or other methods to communicate parts of the array while the user application works on another part of the same array: USE mpi_f08 REAL, ASYNCHRONOUS :: buf(100,100) CALL MPI_Irecv(buf(1,1:100),...req,...) DO j=1,100 DO i=2,100 buf(i,j)=.... END DO END DO CALL MPI_Wait(req,...) It is important that the compiler is not allowed to translate this program (by using temporary memory modifications) into USE mpi_f08 REAL, ASYNCHRONOUS :: buf(100,100), buf_1dim(10000) EQUIVALENCE (buf(1,1), buf_1dim(1)) CALL MPI_Irecv(buf(1,1:100),...req,...) tmp(1:100)=buf(1,1:100) DO j=1,10000 buf_1dim(j)=... END DO buf(1,1:100)=tmp(1:100) CALL MPI_Wait(req,...) While the MPI library receives buf(1,1:100), the numerical part overwrites this part of the array as part of a numerical optimization to achieve one long loop instead of a 2-loop-nesting. The current status of Fortran 2008 + TR 29113 (Version N1845) is that a compiler can ignore the ASYNCHRONOUS attribute, for example, because it does not implement Fortran asynchronous I/O in an asynchronous way, i.e., there is no need for the compiler to make any restrictions on optimization. The goal of the vote SV: extend ASYNCHRONOUS - invent new attribute - undefined: 8-2-3 was, to extend the meaning of the ASYNCHRONOUS attribute that it can be used together with MPI or other asynchronous software. As one can see in https://svn.mpi-forum.org/trac/mpi-forum-web/attachment/ticket/229/mpi-repor... Page 25 lines 5-14 in the pdf (page 550 in the original document), the ASYNCHRONOUS attribute is the only one that can solve the problem. The word "SOLVED" is already based on the "extend ASYNCHRONOUS", (i.e., the extended meaning of the Fortran ASYNCHRONOUS attribute) and can be used for the whole row. With the current state of the TR 29113, the whole line is "NOT solved". VOLATILE is not an option, because it would eliminate any numerical optimization on any code that is used in overlapping communication and computation. Final implication: To solve this problem is absolute necessary for any Fortran implementation of the MPI library. Additionally to the implementation of the "extend ASYNCHRONOUS" in the TR 29113 of Fortran 2008, we plan to write into the MPI-3.0 standard a sentence like this: "A valid implementation of the MPI-3.0 standard requires that the Fortran compiler in use has to guarantee that the ASYNCHRONOUS attribute guarantees that any MPI nonblocking operation can be used on data that is marked as ASYNCHRONOUS. Other parts of the same data can be used in overlapping computation as long as the application uses the ASYNCHRONOUS attribute also in this part of the application software." Best regards Rolf ----- Original Message -----
From: "Craig E Rasmussen" <[email protected]> To: "Craig E Rasmussen" <[email protected]> Cc: "Rolf Rabenseifner" <[email protected]>, "MPI-3 Fortran working group" <[email protected]>, "N.M. Maclaren" <[email protected]>, "Bill Long" <[email protected]>, "Reinhold Bader" <[email protected]> Sent: Tuesday, March 29, 2011 2:50:47 AM Subject: Re: Nonblocking MPI and Fortran temporary memory modifications I've found the relevant paper in J3 meeting minutes (J3 document 09-235r2). The paper is 09-231 "Answer to MPI Forum regarding MPI asynchronous operations" from J3 meeting 188. The minutes state the following regarding this paper:
There was a straw vote taken on what syntax to use to inhibit optimizations for MPI asynchronous operations:
Paper 09-231 "Answer to MPI Forum regarding MPI asynchronous operations" [Rasmussen] discussed how to prevent code-motion and copy-in/out:
The vote was 8 for ASYNCHRONOUS and 2 for new syntax with 3 abstentions.
There was also a report from the INTEROP subcommittee:
/INTEROP: no further action will be taken on 09-185r1, 09-189r1, 09-191, 09-231 - they are all input for the Interop TR N1761
So according to the minutes N1761 was supposed to take this vote and paper 09-231 into account. However, to my knowledge no text was added to the TR in response to this.
This was my bad. I should have realized that just because ASYNCHRONOUS is currently part of the Fortran standard, that this keyword can be used outside of Fortran I/O without further words to that affect in the standard.
We can discuss what to do in response to this in the telecon this evening.
-craig
On Mar 28, 2011, at 4:18 PM, Rasmussen, Craig E wrote:
I'll look for the vote in the minutes.
-craig
On Mar 28, 2011, at 4:12 PM, Rolf Rabenseifner wrote:
Craig, is there a protocol, file, ... on http://www.nag.co.uk/sc22wg5/ where this vote is protocolled? Rolf
----- Original Message ----- From: "Craig E Rasmussen" <[email protected]<mailto:[email protected]>> To: "Rolf Rabenseifner" <[email protected]<mailto:[email protected]>> Cc: "MPI-3 Fortran working group" <[email protected]<mailto:[email protected]>>, "N.M. Maclaren" <[email protected]<mailto:[email protected]>>, "Bill Long" <[email protected]<mailto:[email protected]>>, "Reinhold Bader" <[email protected]<mailto:[email protected]>> Sent: Monday, March 28, 2011 6:14:00 PM Subject: Re: Nonblocking MPI and Fortran temporary memory modifications We've had several discussions regarding the use of ASYNCHRONOUS for the usage required by MPI on the J3 committee. Some members thought that ASYNCHRONOUS shouldn't be used apart from I/O. However, a vote was taken and a large majority voted that the ASYNCHRONOUS attribute should be used for this purpose.
So the question is not about whether a compiler implements ASYNCHRONOUS I/O but whether it respects the ASYNCHRONOUS semantics. Perhaps we need an interp request to formalize this beyond a simple J3 member vote.
-craig
On Mar 27, 2011, at 3:34 AM, Rolf Rabenseifner wrote:
Dear all,
Reinhold showed me that the ASYNCHRONOUS attribute may not help because a compiler may implement asynchronous Fortran I/O with blocking I/O and therefore may ignore all ASYNCHRONOUS attributes.
Please have a look at https://svn.mpi-forum.org/trac/mpi-forum-web/attachment/ticket/229/mpi-repor...
Pages 24-31 in the pdf (pages 549-556 in the original document) show our knowledge about the nonblocking and datatype (MPI_BOTTOM) problems in the combination of Fortran and MPI.
Unfortunately in the taböle on page 550, we have to modify all entries about ASYNCHRONOUS into "NOT solved".
Do you see further solutions?
Do you see further problems with nonblocking and "MPI_BOTTOM", that are not mentioned in this section and that should be.
Is the rest of this section correct? If something is incorrect, it would be important to understand why.
I've reworked this section based on many discussions and on my best knowledge - but I'm not sure whether this was enough.
Best regards Rolf
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected]<mailto:[email protected]> High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner<http://www.hlrs.de/people/rabenseifner> Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
participants (1)
Rolf Rabenseifner
