Re: [MPIWG Fortran] Draft chapter for discussion today
Jeff,
If Chapter 15 is to be renamed, I would agree that 17.1.4 should move. But I'm not sure this is a good idea.
We used already in MPI-2.2 the "Chapter 15. Deprecated Functions" in the general way "Deprecated Interfaces" when we added the total C++ bindings to this chapter, i.e. all C++ constants, functions, ,... . To make the life easy, we should rename Chapter 15 into "Chapter 15. Deprecated Interfaces". This would be consistent to "Chapter 16. Removed Interfaces". The normal text (i.e., text outside of Chap. 15+16) should include as few deprecated features as possible. Best regards Rolf ----- Original Message -----
From: "Jeff Squyres (jsquyres)" <[email protected]> To: "MPI-WG Fortran working group" <[email protected]> Sent: Saturday, February 1, 2014 2:13:05 PM Subject: Re: [MPIWG Fortran] Draft chapter for discussion today
Rolf --
Many thanks; I had forgotten about the variations of "mpif.h" -> "the deprecated mpif.h" throughout the text. I've attached an updated PDF of the whole document this time (not just the bindings chapter) with updates for everywhere mpif.h is mentioned. Search for "ticketWG" to find the instances. The document is labeled MPI-3.1, but this is really a ticket/change for 4.0.
One thing I disagreed with, however, is moving 17.1.4 to chapter 15. Chapter 15 is entitled "Deprecated Functions" -- it is not "Deprecated Functionality".
As Chapter 15 is named right now, I do not believe that 17.1.4 should move there because we did not deprecate any functions (or subroutines). We have deprecated an entire set of bindings... but by the title of Chapter 15, that is not what Chapter 15 covers.
On Jan 17, 2014, at 9:32 AM, Rolf Rabenseifner <[email protected]> wrote:
Dear Jeff,
the content is okay, but I have a few issues with a missing completeness of the ticket:
- MPI-3.0, in Table 2.1, after p18:34 add:
mpif.h (5) [deprecated since] MPI-4.0 [Replacement] mpi or mpi_f08 module
and after p18:37:
(5) Include file.
- The whole text of section 17.1.4 must be moved into the new
15.3 Deprecated since MPI-4.0
15.3.1 Fortran Support through the mpif.h Include File
With MPI-4.0, the Section 17.1.4 on page ... was deprecated and moved into this Section 15.3.1.
[Old text from 17.1.4 with the proposed modifications.] The use of the mpif.h include file is deprecated and may be deleted from a future Version of MPI. ...
17.1.4 Fortran Support through the mpif.h Include File
Since MPI-4.0, the use of the mpif.h include file is deprecated and the content of this section was moved into Section 15.3.1 on page ... .
- MPI-3.0 p11:17 reads
The Fortran version of the same function used with USE mpi or INCLUDE 'mpif.h'.
but should read
And additionally for routines that existed already in MPI-3.0:
The Fortran version of the same function used with USE mpi or the deprecated INCLUDE 'mpif.h'.
- MPI-3.0 p12:40, p30:19 reads
INCLUDE 'mpif.h'
but should read
- MPI-3.0 p13:21 reads
mpif.h or the mpi module
but should read
the mpi module or the deprecated mpif.h
- MPI-3.0 p16:19 reads
the include file mpif.h or the mpi module
but should read
the mpi module or the deprecated include file mpif.h
- MPI-3.0 p19:19 reads
mpif.h and use mpi
but should read
use mpi and the deprecated mpif.h
- MPI-3.0 p32:18 reads
mpi.h and mpif.h
but should read
mpi.h, the Fortran modules mpi_f08 and mpi, and in the deprecated mpif.h
- MPI-3.0 p45:36, p268:38, p270:10, p270:21, p274:14, p277:26, p339:45, p344:26, p346:16, p347:40, p407:48, p409:31, p411:12, p475:15, p475:47, p476:42, 680:36, p680:37 reads
mpif.h
but should read
- MPI-3.0 p367:16, p379:48 reads
but should read
- MPI-3.0 p545:14 reads
the mpif.h
but should read
- MPI-3.0 p605-659 (Fortran Chapter, starting with 17.1.5) reads
mpif.h
but should read
- MPI-3.0 p756:1 reads
Fortran Bindings with mpif.h or the mpi Module
but should read (would be too Long with "deprecated")
Fortran Bindings with the mpi Module or mpif.h
I do not expect that I found all issues, but at least some ;-)
Best regards Rolf
From: "Jeff Squyres (jsquyres)" <[email protected]> To: "MPI-WG Fortran working group" <[email protected]> Sent: Thursday, January 16, 2014 8:13:06 PM Subject: Re: [MPIWG Fortran] Draft chapter for discussion today
We tweaked the document a bit more on the call; here's the final result.
On Jan 16, 2014, at 11:18 AM, "Jeff Squyres (jsquyres)" <[email protected]> wrote:
Sure -- we're starting in about 40 minutes (noon, US Eastern time).
Here's the content from the invite:
The main point of this meeting is to discuss 2 MPI-4 proposals that Jeff will have ready:
1. Deprecate mpif.h. Rolf's suggestion:
MPI-3 p603, chap 17.1.4 1st para -- "mpif.h is strongly discouraged and may be deprecated..." --> change to "is deprecated and may be deleted..." --> Add (short) AtoU, if you have software using mpif.h, you should change it thusly... (see page 603 line 15-17 for inspiration/copy)
2. Freeze the mpi module (no new features). The intent is to focus all of our energies on the mpi_f08 module in the future. If there is push back on this from the Forum, our plan B for this is to modernize the mpi module (i.e., add all the features to the mpi module that we added to the mpi_f08 module). Rolf's suggestions:
--> Add AtoU encourage users to move to mpi_f08
**** You can forward this email invitation to attendees ****
Hello ,
Jeff Squyres invites you to attend this online meeting.
Topic: MPI Forum Fortran WG Date: Thursday, January 16, 2014 Time: 12:00 pm, Eastern Standard Time (New York, GMT-05:00) Meeting Number: 203 787 876 Meeting Password: mpi
------------------------------------------------------- To join the online meeting (Now from mobile devices!) ------------------------------------------------------- 1. Go to https://cisco.webex.com/ciscosales/j.php?ED=248676957&UID=0&PW=NY2UzZmNiNWY3... 2. Enter your name and email address. 3. Enter the meeting password: mpi 4. Click "Join Now".
To view in other time zones or languages, please click the link: https://cisco.webex.com/ciscosales/j.php?ED=248676957&UID=0&PW=NY2UzZmNiNWY3...
---------------------------------------------------------------- ALERT – PLEASE READ: DO NOT DIAL THE TOLL FREE NUMBERS FROM WITHIN THE (408) OR (919) AREA CODES ---------------------------------------------------------------- Please dial the local access number for your area from the list below: - San Jose/Milpitas (408) area: 525-6800 - RTP (919) area: 392-3330
Dialing the WebEx toll free numbers from within 408 or 919 area codes is not enabled (non-Cisco phones). “ If you dial the toll-free numbers within the 408 or 919 area codes you will be instructed to hang up and dial the local access number.” Please use the call-back option whenever possible and otherwise dial local numbers only. The affected toll free numbers are: (866) 432-9903 for the San Jose/Milpitas area and (866) 349-3520 for the RTP area.
------------------------------------------------------- To join the teleconference only ------------------------------------------------------- 1. Dial into Cisco WebEx (view all Global Access Numbers at http://cisco.com/en/US/about/doing_business/conferencing/index.html 2. Follow the prompts to enter the Meeting Number (listed above) or Access Code followed by the # sign.
San Jose, CA: +1.408.525.6800 RTP: +1.919.392.3330
US/Canada: +1.866.432.9903 United Kingdom: +44.20.8824.0117
India: +91.80.4350.1111 Germany: +49.619.6773.9002
Japan: +81.3.5763.9394 China: +86.10.8515.5666
------------------------------------------------------- For assistance ------------------------------------------------------- 1. Go to https://cisco.webex.com/ciscosales/mc 2. On the left navigation bar, click "Support".
You can contact me at: [email protected] 1-408-525 0971
To add this meeting to your calendar program (for example Microsoft Outlook), click this link: https://cisco.webex.com/ciscosales/j.php?ED=248676957&UID=0&ICS=MI&LD=1&RD=2...
The playback of UCF (Universal Communications Format) rich media files requires appropriate players. To view this type of rich media files in the meeting, please check whether you have the players installed on your computer by going to https://cisco.webex.com/ciscosales/systemdiagnosis.php .
CCP:+14085256800x203787876#
IMPORTANT NOTICE: This WebEx service includes a feature that allows audio and any documents and other materials exchanged or viewed during the session to be recorded. By joining this session, you automatically consent to such recordings. If you do not consent to the recording, discuss your concerns with the meeting host prior to the start of the recording or do not join the session. Please note that any such recordings may be subject to discovery in the event of litigation.
On Jan 16, 2014, at 11:01 AM, Bill Long <[email protected]> wrote:
Hi Jeff,
Just starting another meeting. Hopefully I’ll be out in time. Before them, could you resend the webex link - I got a new computer at work with software that seems to delete the email message if you “accept” a meeting.
Cheers, Bill
On Jan 16, 2014, at 9:03 AM, Jeff Squyres (jsquyres) <[email protected]> wrote:
Here is a first cut of the language bindings chapter with changes to:
1. deprecate mpif.h 2. freeze the mpi module
Look for "ticketWG" to see the changes -- I used the standard MPI update/replace macros, so all the changes are easily located. We'll talk through this text on the webex today. The intent is to introduce a ticket (or two?) at the next meeting for 1. and 2.
Note that this PDF does *NOT* reflect the recently-passed tickets for fixing the "linker name" language, etc. This PDF draft for discussion on the webex today is simply the MPI-3.0 text with my updates for 1. and 2.
Updating the MPI-3.1 directory in SVN to include the text from the recent tickets will be a separate effort.
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/ <binding-2.pdf>_______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
Bill Long [email protected] Fortran Technical Suport & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc./ Cray Plaza, Suite 210/ 380 Jackson St./ St. Paul, MN 55101
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) _______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
participants (1)
Rolf Rabenseifner
