Re: [MPI3 Fortran] [Mpi-comments] MPI 3.0: Fortran 2008 interface - issue with the LOGICAL kind
On 3/4/13 1:26 PM, Tobias Burnus wrote:
Bill Long wrote:
There isn't any difficulty about a Fortran wrapper using integers (as C does), and converting them to LOGICAL, but it can't be BIND(C).
There is also no difficulty in having the wrapper arguments being LOGICAL.
subroutine sub (x) bind(c, name="MPI_xxx_f") logical :: x integer(int) :: cx
cx = merge(1, 0, x)
Well, except that compilers might simply reject a default-kind LOGICAL with BIND(C), in line with the Fortran standard.
Ug. I tried 5 compilers. Three (Cray, Intel, PGI) just let it pass. One gave an error, and one gave a warning. What a mess. I'm more convinced now that before that the only practical solution here is to get rid of the LOGICAL arguments, replacing them with INTEGER arguments, which is what the C functions expect anyway. (Alternatively, the problem goes away if support for mpif.h is removed, which I would highly recommend anyway.) I'm trying to work out how to use two layers of wrapper functions to get around the error from that one compiler. Unattractive, to say the least. Cheers, Bill
Your code above assumes that a Fortran compiler allows passing a default-kind LOGICAL to a Bind(C) procedure and that it then can handle that LOGICAL. I think no one really doubts the second part. But the first part is not really covered by the Fortran standard and standard-conforming compilers do exist, which reject default-kind LOGICALs.
J3/WG5 could change the standard such that it supports other LOGICAL kinds besides C_Bool, including kind(.true.). However, if LOGICAL(kind=kind(.true.) / C_INT) exists, users will assume that it acts like C's "int", which will lead to problems. So far, I haven't seen a convincing proposal how to solve this.
Tobias _______________________________________________ mpi3-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-fortran
-- Bill Long [email protected] Fortran Technical Support & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc./Cray Plaza, Suite 210/380 Jackson St./St. Paul, MN 55101
participants (1)
Bill Long
