Re: [MPIWG Fortran] F08 and pair types?
Sorry, but I was too fast with my negative answer. Yes, we have both arguments in the reduction and therefore it would be simple to add a new datatype to the list of allowed datatypes for MIN/MAXLOC in Fortran. Deprecation is too expensive and there is no need. Rolf ----- Original Message -----
From: "Rolf Rabenseifner" <[email protected]> To: "MPI-WG Fortran working group" <[email protected]> Sent: Tuesday, December 8, 2015 7:22:45 PM Subject: Re: [MPIWG Fortran] F08 and pair types?
I'm sorry, but I expect that deprecation of a language binding is not possible for a feature that is still valid in other languages (here C).
This means, that MINLOC and MAXLOC are as they are defined and there is no reason to deprecate them. They are not wrong and nobody want to pay the maintenance costs for modifying existing applications that use MIN/MAXLOC.
The only way to do it better, is to add a new feature, e.g., MINLOC_F08 and MAXLOC_F08 which is valid only for the new mpi_f08 module.
Rolf
From: "Craig Rasmussen" <[email protected]> To: "MPI-WG Fortran working group" <[email protected]> Sent: Tuesday, December 8, 2015 6:30:37 PM Subject: Re: [MPIWG Fortran] F08 and pair types?
The old stuff could be deprecated because all existing compilers that I know of support user-defined types. I assume that "deprecated" means that it still exists in libraries for legacy apps but is no longer really defined in the standard.
-craig
On Tue, Dec 8, 2015 at 9:19 AM, Craig Rasmusen < [email protected] > wrote:
Fortran is a modern language? Wut...
Actually seems like a simple and good change. For example, could define:
MPI_REAL_INT and MPI_INTEGER_INT
However, I'm not sure what would be in the structs (user-defined types). I'll have to ask Squyres what the text following
"The datatype MPI_FLOAT_INT is as if defined by the following sequence of instructions"
means.
-craig
On Mon, Dec 7, 2015 at 4:20 PM, Jeff Hammond < [email protected] > wrote:
I have a reasonable understanding of why the legacy Fortran bindings use 2REAL, 2DOUBLE_PRECISION and 2INTEGER with {MAX,MIN}LOC reductions.
Doesn't modern Fortran provide a way to create struct-like things along the lines of C, such that more appropriate pair types could be used for these?
The relevant text is section 5.9.4 of MPI 3.1.
Jeff
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
_______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) _______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
participants (1)
Rolf Rabenseifner
