Re: [MPI3 Fortran] MPI 3 text is ready
On Sep 22 2010, Rolf Rabenseifner wrote:
Nick and Craig, are these asumptions fully correct?
The issue isn't whether the individual assumptions are correct, but whether they fit together with the existing usage (Fortran and MPI). For example, if choice buffers use that mechanism, then the following code will fail (and is one of the most common ways of using MPI): SUBROUTINE Fred (array, size, root) INTEGER, INTENT(INOUT) :: array(*) INTEGER, INTENT(IN) :: size, root INTEGER :: error CALL Scatter(array,size,MPI_INTEGER,root,MPI_COMM_WORLD,error) END SUBROUTINE Fred The failure is fundamental and unfixable in the current design of the Interop TR - I proposed an alternative that would not fail, but it was felt to be outside the TR's scope. The fix is a source change: SUBROUTINE Fred (array, size, root) INTEGER, INTENT(INOUT) :: array(*) INTEGER, INTENT(IN) :: size, root INTEGER :: procs, rank, error CALL MPI_Comm_procs(rank,error) CALL MPI_Comm_rank(rank,error) IF (rank == root) THEN CALL Scatter(array(:procs*size),size,MPI_INTEGER, & root,MPI_COMM_WORLD,error) ELSE CALL Scatter(array(:size),size,MPI_INTEGER, & root,MPI_COMM_WORLD,error) END IF END SUBROUTINE Fred I assert that that level of incompatibility is a major issue. Regards, Nick.
participants (1)
N.M. Maclaren
