[MPI3 Fortran] Effect of volatile
At the MPI Forum meeting this week there was a discussion on the effects of volatile (the subject has come up on the WG5 list as well) on performance. MPI users are very concerned about performance and are worried that providing the volatile attribute to an array will substantially affect performance. However, I think the following should work with minimal performance implications: --------------------- buf(1) = 1 call MPI_Irecv(buf, ...., request,...) ! .... do work without buf BLOCK volatile :: buf call MPI_Wait(request, ...) END BLOCK ! now buf is ready to use x = buf(1) --------------------- I believe that the effects of the volatile statement within the block is AS IF MPI_Wait were called with buf as a parameter and the dummy variable was INTENT(INOUT): any registers containing values associated with buf will be flushed and code motion will be restricted. Volatile would only be in effect within the block construct and would not have any performance implications otherwise. At the assignment statement, x = buf(1), the value assigned to x would have to be retrieved from memory and could not be obtained from a register. I should note that buf can't actually be passed as a parameter to MPI_Wait as the request handle could be associated with any number of variables, not just buf. Regards, Craig
participants (1)
Craig Rasmussen
