Re: [MPIWG Fortran] Question about MPI_Status_f2f08() and _f082f()
On Jul 10, 2020, at 11:11 AM, Jeff Squyres (jsquyres) <[email protected]> wrote:
2) \begin{unpopular} Why are the legacy mpi module and mpif.h still included in the spec? These are embarrassingly obsolete. If this was fixed, none of the above mentioned conversion routines would be needed. \end(unpopular}
I would love it if we could ditch -- at a minimum -- mpif.h.
However, there's oodles of legacy code out there that uses it. That's why even deprecating it gets shouted down at Forum meetings.
We have the same discussions in the Fortran committee about deleting things, or at least making them “obsolescent”, which seems functionally similar to deprecated in MPI. In the end, we specify certain archaic and now-redundant features as deleted with full knowledge that implementors will not remove the capabilities from compilers because of old codes. However, the Intent is to guide programmers writing new code in the direction of using the new (hopefully better) alternatives. And, relevant to the present discussion, deleting certain old stuff makes the standard document cleaner. Fundamentally, MPI is a C library. Other languages, like C++ and Python, don’t require separate bindings specified in the MPI spec because they can call C library routines. The whole mpi_f08 module exercise was to demonstrate that Fortran can now do the same. The whole idea of specifying a separate Fortran MPI interface needs to be rethought. Perhaps something like “This version of MPI specifies the contents of a vendor-required Fortran module for MPI that allows access to the underlying C specification. The separate language binding for Fortran has been deleted, but is still available for historical reference in the MPI-3 and earlier specifications.” That should allow for a significant simplification of the MPI specification document. Cheers, Bill Bill Long [email protected] Principal Engineer, Fortran Technical Support & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9143 Cray, a Hewlett Packard Enterprise company/ 2131 Lindau Lane/ Suite 1000/ Bloomington, MN 55425
participants (1)
Bill Long
