[MPI3 Fortran] Derived-data, a new/late comment on Fortran WG5 ballot N1846
Dear John, dear members of the WG5 and J3 Fortran committees, I'm sorry that with this additional comment on problems regarding derived types, I missed the deadline of the N1846 ballot for the N1845 draft of the TR 29113 on extensions on Fortran-C interoperability. It looks like that there are two problems with derived types and the Fortran-MPI-compatibility with a background in the Fortran-C-interoperability. Problem A: Sequence derived types in the MPI routine interfaces, which are declared with BIND(C); this problem occurs with the new MPI handles and MPI statuses. Problem B: Derived type, SEQUENCE derived type, and BIND(C) derived type as actual user buffers for TYPE(*),DIMENSION(..) dummy arguments in BIND(C) MPI routine interfaces. Problem C: Based on problem B we have the question whether the new TYPE(*),DIMENSION(..) dummy arguments in BIND(C) MPI routine interfaces really allow all actual arguments that were possible with implicit interfaces or with explicit interfaces in combination with pragmas like !DEC$ ATTRIBUTES NO_ARG_CHECK :: buf and !$PRAGMA IGNORE_TKR buf At least for problems A and B, the solution may be "simple" by allowing SEQUENCE derived types as element of a BIND(C) derived type and in BIND(C) subroutine dummy arguments. Why we need this is shown in very detail in the following description of Problems A and B. A still open question is Problem C. To Problem A: ------------- For better type-safety and compile-time argument-checking, the MPI Forum wants to use named types for MPI handles and MPI status. In MPI-1.1 up to MPI-2.2, we use INTEGER and INTEGER, DIMENSION(MPI_STATUS_SIZE) for this. With the new module mpi_f08 in MPI-3.0, we want to use MODULE mpi_f08 IMPLICIT NONE TYPE :: MPI_Comm SEQUENCE INTEGER :: MPI_VAL END TYPE MPI_Comm TYPE :: MPI_Status SEQUENCE INTEGER :: MPI_SOURCE INTEGER :: MPI_TAG INTEGER :: MPI_ERROR INTEGER :: MPI_intern_highsize INTEGER :: MPI_intern_lowsize END TYPE MPI_Status END MODULE mpi_f08 Within existing user applications, it is important, that the new handles and status variables can be used everywhere, where the old-style INTEGER handles and INTEGER-array statuses are already used. This definition can be used in - user-defined arrays of handles or statuses - handles and statuses as part of a user-defined common block - handles and statuses as part of a user-defined derived type - handles and statuses as part of a user-defined sequence derived type In my attached the tests Bu1.f90, Bu2.f90 and Bu3.f90, this was checked by Reinhold Bader for many compilers. If an application already uses C-Fortran interoperability, it may be that such handles and statuses are also declared with a BIND(C) derived type. The test Bu4.f90 showed that this works with ifort and pgi, but is rejected by gfortran, nagfor, xlf, crayftn, and pathscale. In the tests Au1, Au2, Au3, Au4, the SEQUENCE attribute was removed from the definition of MPI handles and statuses; nearly all compiler reject nearly all use-cases. In the tests Cu1, Cu2, Cu3, Cu4, the SEQUENCE was substituted by BIND(C). This is rejected by all compilers for the case that a handle or status is part of a user-defined sequence derived type (see Cu3). Another problem is the implementation of the MPI routines. We want to be able to use wrappers written in C, i.e., to use BIND(C) for the definition of MPI routines. The test Bc1 calls an MPI routine that has a pure Fortran implementation, while Bc2 calls an MPI routine that is implemented with BIND(C). Bc1 of course works with all compilers, while Bc2 is rejected by gfortran, nagfor, xlf and pathscale. Same rejections occur if the handles are defined without SEQUENCE (see Ac2). Of course, in case C, handles are done with BIND(C), all compiler accept the MPI routines (see Cc2), but this does not really help, because the application use-case Cu3 was rejected by all compilers. How can this problem be solved? Sequence derived types are similar to common blocks and as long as normal Fortran types (INTEGER, REAL) are allowed with BIND(C), why is a sequence of such types is not allowed with BIND(C)? Which additions would be necessary to solve this problem within the TR 29113? To Problem B: ------------- As an example, here an MPI interface SUBROUTINE MPI_xxx(buf,...) BIND(C) TYPE(*), DIMENSION(..) :: buf END within the new MPI module and the following user code TYPE :: user_xxx SEQUENCE REAL, DIMENSION(100) :: x, y, z INTEGER, DIMEMSION(20) :: a, b END TYPE user_xxx TYPE(user_xxx) :: strct(5) CALL MPI_xxx(strct, ...) When I understood correctly, then strct is handed over through a dope vector with elem_len = sizeof(strct(1)). Without any SEQUENCE or BIND(C) for user_xxx, the compiler may optimize and modify the memory layout of the structure during the execution of the application, i.e., any address difference need not to be constant, e.g., LOC(strct(5)%b(1)) - LOC(strct(1)%x(1)) need not to be the same during the whole execution and within the application and the called MPI routine. Is this correct? To achieve a well-defined memory layout, the user has to use SEQUENCE or BIND(C) for user_xxx. Therefore in the past, the advice for MPI users was, to use the SEQUENCE attribute. Results from the compiler tests are: All compiler allow the usage of SEQUENCE and BIND(C) derived type as actual buffer arguments in implicit interfaces of MPI routines, see cases 1 and 2 in the tests to problem B. All compiler with a IGNORE_TKR directive allow SEQUENCE and BIND(C) derived type as actual buffer arguments in an explicit interface defined with INTERFACE, see cases 4 and 5. Normal derived types (that are neither SEQUENCE, nor BIND(C), nor defined within a module) cannot be used as such an actual buffer argument with the IBM xlf compiler, see cases 3 and 6. Same results have been obtained with explicit interfaces defined with CONTAINS, except for xlf, which does not allow the IGNORE_TKR directive outside of INTERFACE declarations. Do I understand correctly, that with N1845 of TR 29113, TYPE(*),DIMENSION(..) works only with BIND(C) derived types, but - not with normal derived types, and - not with sequence derived types? Is there a possibility to extend the TR that also sequence derived type can be handed over to TYPE(*), DIMENSION(..) dummy arguments? Problem C: ---------- Do we have other actual arguments that could be used in implicit interfaces or in explicit interfaces with these special pragmas, and that are still forbidden for TYPE(*),DIMENSION(..) dummy arguments? Best regards and my apologies that we detected the problem not earlier, Rolf --------------------------------------------------------- Test and file names for Problem A: ---------------------------------- Implementing new MPI handles and status with ... A = Fortran derived type B = Fortran sequence derived type C = Fortran BIND(C) derived type Usage of new MPI handles and status in the application within ... u1 = a user defined common block u2 = a user defined derived type u3 = a user defined sequence derived type u4 = a user defined BIND(C) derived type Call an MPI routine that is defined c1 = without BIND(C) c2 = with BIND(C) Compiler: Result are: R - rejected by the compiler i - compiles but issues an information or warning y - compiles Test --> | A A A A A A | B B B B B B | C C C C C C | | u u u u c c | u u u u c c | u u u u c c | | 1 2 3 4 1 2 | 1 2 3 4 1 2 | 1 2 3 4 1 2 | ------------------+--------------+--------------+--------------+ ifort 6.1 | R y R y y y | y y y y y y | R y R y y y | ifort 11.1 | y y R y y y | y y y y y y | y y R y y y | ifort 12.0 | y y R y y y | y y y y y y | y y R y y y | ------------------+--------------+--------------+--------------+ gfortran 4.6 | R y R R y R | y y y R y R | i i R i i i | nagfor 5.2 | R i R R i R | y i i R i R | y i R i i i | ------------------+--------------+--------------+--------------+ xlf 13.1 | R y R R y R | y y y R y R | y y R y y y | crayftn 7.3 | R y R R y y | y y y R y y | y y R y y y | ------------------+--------------+--------------+--------------+ pgi 11.3 | y y R y y y | y y y y y y | y y R y y y | pathscale 3.3b | R i R R i R | i i i R i R | i i R i i i | ------------------+--------------+--------------+--------------+ Notes: "i" entries from the NAG compiler are due to defined but unused entities. "i" entries from the gfortran compiler are wrt INTEGER, ... potentially being non-interoperable. "i" entries from the Pathscale compiler are (irrelevant) link-time messages. Tar file: - MPI3_bind-C_sequence_tests.tar.gz (attached) ----------------------------------------------------------------- Test and file names for Problem B: ---------------------------------- Test and file names: derived_types_test_1_impl_integer.f90 derived_types_test_2_impl_sequ_bc.f90 derived_types_test_3_impl_derived.f90 derived_types_test_4_expl_integer.f90 derived_types_test_5_expl_sequ_bc.f90 derived_types_test_6_expl_derived.f90 derived_types_test_7_all.f90 derived_types_test_1+2_impl_int+seq+bc.f90 with impl = Implicitly defined MPI routine is called. expl = Two explicitly defined MPI routines are called - without BIND(C), - with BIND(C) in the subroutine declaration. The buf dummy argument is defined with a TKR ignore directive. integer = Actual argument is a derived type and it is passed through first (integer) element. Three different derived types are used: - normal, - with SEQUENCE attribute, - with BIND(C) attribute. sequ_bc = Actual argument is a derived type with - with SEQUENCE attribute, - with BIND(C) attribute. derived = Actual argument is a normal derived type. The last test "1+2" is a special test to show a compile-time error only detected by nagfor. This test compines the calls in ..._1_impl_integer.f90 and ..._2_impl_sequ_bc.f90. Compiler results may be: R - rejected by the compiler Rs - rejected by the compiler (routines and main separately compiled) i - compiles but issues an information or warning and runs correctly y - compiles and runs correctly ys - compiles and runs correctly (routines and main separately compiled) N - compiles, then runs with run time failure Test --> | ---impl--- ---expl--- all impl | int seq drv int seq drv int+seq | 1 2 3 4 5 6 7 1+2 ------------------+--------------------------------------- ifort 11.1 | y y y y y y y y ifort 12.0 | y y y y y y y y ------------------+--------------------------------------- gfortran 4.6 | y y y R R R R y nagfor 5.2 | ys ys ys Rs Rs Rs Rs Rs ------------------+--------------------------------------- xlf 13.1 | y y R y y R R y crayftn 7.3 | i i i y y y i i ------------------+--------------------------------------- pgi 11.3 | y y y y y y y y pathscale 3.3b | i i i y y y i i ------------------+--------------------------------------- Notes: - Compile-time information, warning and errors with the CALL statements gfortran + 1,all : Rank mismatch warning (rank-1 vs scalar lines for all invocations) gfortran + 2,3,all : Type mismatch warning gfortran + 4,all : Rank mismatch error (rank-1 vs scalar lines for all invocations), i.e., none of the TKR_IGNORE directives work gfortran + 5,6,all : Type mismatch error, i.e., none of the TKR_IGNORE directives work nagfor + 4,all : Rank mismatch error (rank-1 vs scalar lines for all invocations), i.e., none of the TKR_IGNORE directives work nagfor + 5,6,all : Type mismatch error, i.e., none of the TKR_IGNORE directives work nagfor + 1+2, all : Error: Inconsistency between several calls of implicitly defined routine: "Inconsistent data type INTEGER (previously USER_BUFFER_NORMAL_TYPE) for argument 3 in reference to FOO_IMPL", i.e., a combination of the tests in 1 and 2 or 3 may fail. crayftn+1,2,3,all,1+2 : Rank mismatch diagnosed, but runs correctly xlf + 3,6, all : Severe error: "A derived-type object that appears as an actual argument in an external procedure reference must be of a sequence type or a type with the BIND(C) attribute, unless it is use-associated or of a type that is use-associated or defined in the specification part of a module. pathscale+1-3,all,1+2 : Warns about rank mismatch, but runs correctly. - Compile-time information, warning and errors with the declaration statement of MPI_foo..., i.e., when compiling the MPI library: gfortran + 4,5,6,all : Warning with BIND(C) declarations: INTEGER may not be interoperable with C, related to line "SUBROUTINE MPI_foo_ex_c(c1,c2,buf,test1,test2) BIND(C)" nagfor + "routines" : Additional information that BIND(C) is an "extension" in line "SUBROUTINE MPI_foo_ex_c(c1,c2,buf,test1,test2) BIND(C)" - Other compile-time information, warning and errors: gfortran+1,2,4,5,all,1+2:Warning with BIND(C) declarations: INTEGER may not be interoperable with C, related to line "TYPE, BIND(C) :: user_buffer_bind_c_type" nagfor+1,2,4,5,all,1+2: Additional information that BIND(C) is an "extension" in line "TYPE, BIND(C) :: user_buffer_bind_c_type" - Runtime errors were never detected, i.e., in the cases with actual argument = buf%VAL1 (i.e., the first element of the derived type), all compilers used call by reference, i.e., the called implicit or explicit routines could correctly access also the second element of the derived type. Tar file: - MPI3_derived_types_test.tar.gz (attached) Acknowledgments: I want to thank Reinhold Bader (LRZ, Munich, Germany) who made all the compiler protocols. -- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
participants (1)
Rolf Rabenseifner
