Re: [MPIWG Fortran] Type of MPI_Status
On Mar 17, 2014, at 3:19 PM, Jeff Hammond <[email protected]> wrote:
On Mon, Mar 17, 2014 at 4:52 PM, Craig Rasmussen <[email protected]> wrote:
Jeff and I had a similar conversation last week. It is my viewpoint that the MPI-3 interfaces are formal interfaces that can be adapted by an implementation in a way that formally meets the specification.
For Open MPI I believe that Jeff will add configuration magic to check is INTEGER(C_INT) and default INTEGER have the same KIND value. This should be true for 100% of the compilers. If not, then that compiler will not be able to build Open MPI.
So what you're saying is that users will not be able to use "-i8" or equivalent when building OpenMPI? That is quite common despite being totally evil.
I apparently did not read Craig's not closely enough. No, what he described is not what I'm doing. See later emails in this thread. -- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
participants (1)
Jeff Squyres (jsquyres)
