Re: [MPI3 Fortran] Start discussing new Fortran binding
Hi, folks. This is Steve Lionel from the Intel Fortran development team. I've asked to join this list to help with the Fortran bindings to MPI-3. Here's my comments on the current discussion.
Not being a fortran guy, here's a few options that jump to mind (some/ all of these make be senseless in Fortran):
1. Can there be a fortran integer equivalent than can map to either of those, given an appropriate KIND?
Yes, this would be INTEGER(C_INTPTR_T) which is an integer kind that is the size of a pointer for the companion processor. This is equivalent to C's intptr_t type. Note that it isn't guaranteed that there is such an integer kind, though I'd expect that there would be. C_PTR is a type on its own and not a KIND value. It is an "opaque" type that can be manipulated by functions such as C_F_POINTER which "converts" a value of type C_PTR to a Fortran pointer. For MPI arguments that are "handles" - that is, values that are simply fetched, stored and passed and not used arithmetically, then type(C_PTR) would be appropriate. But there's a better option - see below.
2. Is there a way to use a preprocessor to replace something like this
integer(MPI_HANDLE_TYPE), value, intent(in) :: datatype
with either C_INT or C_PTR, depending on what the implementation requires?
The proper (IMO) way to do this in Fortran is as follows: type, BIND(C) :: MPI_HANDLE_TYPE private type(C_PTR) :: handle end type MPI_HANDLE_TYPE This allows the user to declare things of type(MPI_HANDLE_TYPE) but makes the contents inaccessible other than passing, storing or fetching. The BIND(C) tells the Fortran compiler that this is an interoperable type and it is not allowed to pad it or rearrange the contents.
3. Does F03 have the equivalent to C's "typedef" such that we could create handle types that map to integer(C_INT) or type(C_PTR) (and the user doesn't need to know)?
See above. Steve Lionel Developer Products Division Intel Corporation Nashua, NH
participants (1)
Lionel, Steve
