Re: [MPIWG Fortran] [Mpi-comments] MPI_Comm_spawn_multiple: parameter description and Fortran bindings
Bill,
That being said, the standard does not state that, and it is unclear whether 'array_of_commands' should be
NULL-terminated (so to speak) or not.
Fortran characters are NOT null terminated.
I was referring the array and not the characters, so let me clarify this : In example 10.2, the array of commands is CHARACTER*25 commands(2), commands(1) = ' ocean ' commands(2) = ' atmos ' By reading the standard literally, it was unclear to me whether this should have been CHARACTER*25 commands(3), commands(1) = ' ocean ' commands(2) = ' atmos ' commands(3) = ' ' FWIW, Open MPI currently expects the latter form (see https://github.com/open-mpi/ompi/issues/4788) I initially thought it was a simple bug, but on second thought, I am still on the fence whether this should be regarded as a simple bug or a correct/literal interpretation of the standard. Cheers, Gilles On Fri, Feb 9, 2018 at 7:07 AM, Bill Long <[email protected]> wrote:
On Feb 8, 2018, at 3:44 PM, Jeff Squyres (jsquyres) <[email protected]> wrote:
And the Fortran binding is
MPI_COMM_SPAWN_MULTIPLE(COUNT, ARRAY_OF_COMMANDS, ...) INTEGER COUNT CHARACTER*(*) ARRAY_OF_COMMANDS(*)
Note that the character*(*) syntax is archaic (as of 25+ years ago). The normal way of writing this is character(*).
Intuitively, it seems obvious that 'array_of_commands' is an array of 'count' commands.
That is what I would assume. The user would be responsible for declaring the array elements large enough to hold the longest command. (All the elements of the array have the same length).
Back to the Fortran binding, the following prototype, which is somehow consistent with 'array_of_argv',
could (help to) clear the confusion. The same comments also apply to the Fortran 2008 binding.
CHARACTER*(*) ARRAY_OF_COMMANDS(COUNT)
This is also fine, and clearer in terms of the expected minimum size of ARRAY_OF_COMMANDS.
Cheers, Bill
Bill Long [email protected] Principal Engineer, Fortran Technical Support & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9143 Cray Inc./ 2131 Lindau Lane/ Suite 1000/ Bloomington, MN 55425
participants (1)
Gilles Gouaillardet
