Re: [MPIWG Fortran] Type of MPI_Status
On Mar 18, 2014, at 9:10 AM, Rolf Rabenseifner <[email protected]> wrote:
Jeff,
based on Bill's explanations I understand that all is the same:
KIND(0) = KIND(1) = KIND(237834) = KIND(any default INTEGER number)
Right.
= KIND(any default INTEGER variable) = KIND(ICVDhjk) = KIND(INTEger)
provided that there is no "IMPLICIT NONE"and therefore, the with I beginning variables ICVDhjk and INTEger are automatically of type default INTEGER
Or if you explicitly declare the argument to be a default integer, which is safer in case you accidentally choose a variable also used by the surrounding code.
Remark: You should never use KIND(INTEGER) because it may
Reasonable rule of thumb for various reasons. But this also excludes KIND(INTEger) since variable names in Fortran are case-insensitive. Cheers, Bill
cause a name conflict if the MPI applications declares an own variable with name INTEGER.
Best regards Rolf
----- Original Message -----
From: "Jeff Squyres (jsquyres)" <[email protected]> To: "MPI-WG Fortran working group" <[email protected]> Sent: Tuesday, March 18, 2014 2:23:24 PM Subject: Re: [MPIWG Fortran] Type of MPI_Status
On Mar 17, 2014, at 6:09 PM, Bill Long <[email protected]> wrote:
Crap, again? I keep forgetting which language I'm programming in. I checked this with gfortran and it worked (as it should, but not in the way I thought it would). That is why I originally suggested to Jeff it be
KIND(1)
(because the literal 1 is an integer), but he asked what the heck does that mean so I came up with an example that I thought was more clear (but was actually worse).
More important, 1 is of type *default* integer, which is the requirement here.
So -- I'm now confused. Should I use KIND(0) or KIND(1)? Both have been cited in this email thread.
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
_______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) _______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
Bill Long [email protected] Fortran Technical Suport & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc./ Cray Plaza, Suite 210/ 380 Jackson St./ St. Paul, MN 55101
participants (1)
Bill Long
