Re: [MPI3 Fortran] Serious problem/bug in MPI libraries with the alignment of MPI_DOUBLE_PRECISION
Dear all who contributed to this discussion, for MPI-3.0, I got the strong conclusion that we should not try to define anything about alignment in the combination of Fortran and MPI. I'll try to choose careful wording and advices. Thanks and best regards Rolf ----- Original Message -----
From: "Bill Long" <[email protected]> To: [email protected] Sent: Thursday, September 29, 2011 2:37:13 PM Subject: Re: [MPI3 Fortran] Serious problem/bug in MPI libraries with the alignment of MPI_DOUBLE_PRECISION On 9/29/11 3:22 AM, Rolf Rabenseifner wrote:
I never talked about DOUBLE PRECISION size. All platforms used a size of 8 bytes.
I hope that assumption is not embedded in the MPI design, since I know of examples where default REAL is 8 bytes and DOUBLE PRECISION is 16 bytes.
The background of the problem is: In the Intel compiler on IA64 and IBM's xlf on Power, the alignment of (8 byte) DOUBLE PRECISION is - 4 byte within a SEQUENCE derived type (always the first number in my summary sheet) - 8 byte within a BIND(C) derived type (always the second number in my summary sheet)
The rules for BIND(C) layouts are determined by the particular compiler that is identified as the "companion processor" for the Fortran compiler. Usually it is the C compiler from the same vendor. These rules do not need to match those for a SEQUENCE type.
And MPI has strong alignment rules on MPI-2.2 page 78 and 79.
The problem is: This alignment is in some MPI libraries 4 and others 8 byte with those compilers (always the third number in my summary sheet). And a standard is not a standard if it is not standardizing such things. It would be only a problem-description.
It depends on what kind of standard it is. If it is a standard for a higher level language, like Fortran, that is intended to be (relatively) machine hardware independent, then I would expect alignment specifications to be largely omitted as inappropriate and harmful to efficient implementations. If the standard is for calling sequence conventions, or for internal memory representations, the the expectations are different.
Cheers, Bill
Rolf
From: "Craig E Rasmussen"<[email protected]> To: "MPI-3 Fortran working group"<[email protected]> Sent: Wednesday, September 28, 2011 7:58:00 PM Subject: Re: [MPI3 Fortran] Serious problem/bug in MPI libraries with the alignment of MPI_DOUBLE_PRECISION Rolf,
I don't know where you get the idea that a DOUBLE PRECISION variable should occupy 4 bytes. The standard says:
A nonpointer scalar object of type double precision real or default complex occupies two contiguous numeric storage units;
The derived types we worked out in Santorini were especially constructed so that double precisions numbers would be misaligned if the compiler was forced to do bad things via the SEQUENCE statement. Can you give me an idea which part of the tests we wrote indicate a double precision number is 4 bytes?
Also, I checked the F2003 and F2008 standards and this wording (see above) has not been changed.
-craig
On Sep 28, 2011, at 11:00 AM, Rolf Rabenseifner wrote:
A very good question. Instead of referring to SEQUENCE, it should say
that MPI_DOUBLE_PRECISION would use the numeric storage sequence rules
(16.4.3.1 in Fortran 2003) for alignment.
Nick, please can you explain, what "16.4.3.1 in Fortran 2003" tells about alignments. In SEQUENCE derived types and COMMON blocks, when I understand this correctly, then DOUBLE PRECISION must have also one numerical storage unit as alignment, i.e., with REAL=4 bytes, DOUBLE PRECISION alignment must be also 4 byte, i.e., exactly what the Intel compiler is doing in a SEQUENCE derived type or COMMON block.
The implication is that the compiler issues nice "warnings" about misaligned data.
Do I understand correctly, that the other compilers with REAL-size=4 byte and DOUBLE PRECISION size and alignment = 8 byte, do it wrong, i.e.not according to Fortran 2003 or 2008?
Best regards Rolf
To: "Fab Tillier"< [email protected]>
Cc: "Rolf Rabenseifner"< [email protected]>, "Jeff Squyres"< [email protected]>, "Shinji Sumimoto"
< [email protected]>, "Hubert Ritzdorf"< [email protected]>, "Howard Pritchard"< [email protected]
"Brian Smith"< [email protected]>, "Charles J Archer"< [email protected]>, "Rajeev Thakur"< [email protected]>,
"Bill Long"< [email protected]>, "Bill Gropp"< [email protected]>, "Richard Graham"< [email protected]>, "Iain Bason"
Sent: Wednesday, September 28, 2011 10:26:37 AM
Subject: RE: Serious problem/bug in MPI libraries with the alignment of MPI_DOUBLE_PRECISION
On Sep 27 2011, Fab Tillier wrote:
It seems that all the a == 4 results come from using the Intel
Fortran
compiler suite. Given that Microsoft doesn't ship a Fortran
compiler,
mandating a == 8 doesn't put us in a position to succeed. Therefore,
I
cannot support such a proposal.
I agree that Microsoft should not be forgotten, but it is not a major
platform for MPI use, and the tail should not wag the dog. We have the
ghastly example of C99 long long where some people claimed Microsoft
compatibility required an incompatible change to the standard; largely
as a result, the official C standard is no longer used as a portable
programming base by a good half of the C-using community.
however, shouldn't a DOUBLE PRECISION BIND(C) derived type map to
MPI_DOUBLE, not MPI_DOUBLE_PRECISION?
Can't we simply document that MPI_DOUBLE_PRECISION (and any Fortran
types
that need similar treatment) apply only to SEQUENCE derived types,
while
BIND(C) derived types should use the C types?
Slightly related to this, can't we PLEASE deprecate those horrible
MPI_INTEGER8 etc. types? They have been a portability disaster for
half a century, even among Fortran IV compilers (where they started)!
MPI has provided some perfectly good mechanisms to use Fortran's
selectable KINDs. The reason that it is related is that there is no
guarantee that a compiler will give them the same alignment as another
type even if they use the same storage, because they are non-standard
and therefore any specification is the compiler's choice.
Nick Maclaren.
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) _______________________________________________ mpi3-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-fortran
-- Bill Long [email protected] Fortran Technical Support & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc./Cray Plaza, Suite 210/380 Jackson St./St. Paul, MN 55101
participants (1)
Rolf Rabenseifner
